Changed tie rods. Now there are issues.
by weebl
1 minute 43 seconds ago
Castrol Magnatec 10W40 & Edge 10W30 Sale at Repco
by SR5
28 minutes 51 seconds ago
Bosch water injection boosts MPG and cut emissions
by HTSS_TR
Yesterday at 11:09 PM
Nissan tiida/ vesa coolant?
by Nissan101
Yesterday at 10:42 PM
my Buick 03 lesabre has a flashing radio light?
by snake123
Yesterday at 10:25 PM
5000 miles in the Caprice
by ls1mike
Yesterday at 10:01 PM
Copper Reactivity and BMW Blue Coolant
by TXCarGeek
Yesterday at 09:24 PM
lubegard biotech xle
by mobilaltima
Yesterday at 09:05 PM
Schaeffer 5w-40 in Jeep 4.0
by JeepWJ19
Yesterday at 08:53 PM
PP and PU 45% off this wk at CT !!!
by ST2008
Yesterday at 08:49 PM
Photographic evidence of HDEO / synth oil cleaning
by OldEuroCarLover
Yesterday at 08:35 PM
Limited Slip Additive needed for G80?
by Nick1994
Yesterday at 08:28 PM
JoeI, binarycache, MarkieB, albertson, Chevy538487
58973 Registered Users
30 registered (4WD, akela, carlprop, daves87rs, CKN, david_ES2, 4 invisible), 946 Guests and 5 Spiders online.
58973 Members
66 Forums
253841 Topics
Page 1 of 2 1 2 >
#2419454 - 10/29/11 08:16 AM Need advice,2012 Chevy Impala 3.6
rjh245 Offline
Loc: PA
Wife has a new 2012 Impala with a 3.6 engine. I was thinking about using either Mobil 1 or Extemded preformance. I was also going to use the Oil Life Monitor. The wife drives about 8K miles a year and it is almost all off dighway driving. Back roads with short trips.
Can I trust those oils with the Oil Life Monitor and is the Mobil brand filter a goos choice or should I stick with the AC delco?
#2419465 - 10/29/11 08:37 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: rjh245]
mrsilv04 Offline
Loc: Illinois
I don't see the need for M1 Extended Performance.
Using the OLM, you would be safe even using a conventional oil. Using Mobil 1 (non-EP) would still give you an additional margin, just to be sure.
Either an AC Delco or an M1 oil filter would perform fine.
Whatever you do... do NOT speed through the town of Gauley Bridge, WV.
#2419470 - 10/29/11 08:41 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: rjh245]
Travis99LS1 Offline
Loc: NC
Yes those oils will be fine going off the oil life monitor. Either one of those filters are fine..the Mobil 1 is probably a little better. You may also want to consider Pennzoil platinum or ultra..any of them are great oils
2015 Ford Fiesta ST..Oxford white..Orange Recaros
#2419489 - 10/29/11 09:23 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: rjh245]
SrDriver Offline
Loc: Southeast Alabama
If I am not badly mistaken this engine requires GM Dexos1 approved oils?
Info about Dexos
#2419491 - 10/29/11 09:26 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: rjh245]
229 Offline
Loc: Mid Atlantic
M1 is dexos1 approved. I would use a P1 filter or Bosch EP. Change the air filter early along with the oil because of the driving conditions.
Eneos Dealer
#2419536 - 10/29/11 10:23 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: rjh245]
Nick R Offline
Loc: Albany, NY
Pennzoil Platinum and a PureONE filter. Rinse, repeat.
Also, I was unaware until now that the Impala gets the new 3.6L and 6A. Good news. However, despite that I still think the impala is due for a ground up redesign, though it has many good points.
Edited by Nick R (10/29/11 10:24 AM)
2013 Ford Focus SE 2.0L/73,000miles/Motorcraft Blend 5W-20/FL-400S
#2419541 - 10/29/11 10:32 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: SrDriver]
rjh245 Offline
Loc: PA
I was told at the dealer that if I don't use the dexos oil i should stick with 3k oil changes.
Yes, this Impala has the new 3.6 engine. I had read a few posts that it may be an engine that is hard on oil. But I have nothing to back up that claim.
#2419555 - 10/29/11 10:43 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: rjh245]
Nick R Offline
Loc: Albany, NY
The only real reason that engine would be hard on oil is because it is DI, but most recent UOAs show that it really isn't that bad, not as bad as it was when new. That's why I'm slightly concerned about the nox, I have no idea what to expect out of that 3.0 DI. But I will tell you, I'm not one bit concerned about the DI itself at all.
#2419560 - 10/29/11 10:47 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: Nick R]
rjh245 Offline
Loc: PA
So it sounds like the opion is that if I run with Mobil 1 and use either a Mobil or AC Delco filter I will be fine using the oil change monitor. I do know my wife hopes to keep the car for 200,000 miles.
#2419561 - 10/29/11 10:47 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: rjh245]
gulian Offline
Loc: canada
Wouldn't the Mobil filter void the warranty, and I would want to be sure to have the correct pressure coming out of that filter to safeguard that brand new engine. As far as price, they are very close. As long as the oil is dexos rated it would be a good idea from all I've read is to go 5k oci's.
Edited by gulian (10/29/11 10:50 AM)
#2419565 - 10/29/11 10:50 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: rjh245]
Nick R Offline
Loc: Albany, NY
Mobil 1 isn't a bad oil, but I would go with PP as I said before. It's about the same price, but I personally feel that it's a better oil. It's JMO though, so take it for what it's worth. PP is one of the favorite oils here on BITOG. A lot of engines seem to run quieter on it, and fwiw, most PP UOAs look better than M1. But that doesn't really mean all that much.
There is no reason to spend that much on a filter though. Use a Purolator PureONE. They are half the price, and are still excellent filters.
#2419567 - 10/29/11 10:50 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: gulian]
rjh245 Offline
Loc: PA
I am told the M1-212 is a cross reference to the pf-63. Maybe that is incorrect.
#2419579 - 10/29/11 11:04 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: rjh245]
1999nick Offline
Loc: Germantown TN 38138
I'll bet she gets real tired of that car before 25 years are up. Yes, I agree that you should use any dexos approved oil in conjunction with the oil life monitor and you will be fine.
Edited by Bill in Utah (10/29/11 01:22 PM)
Edit Reason: fixed quote
#2419585 - 10/29/11 11:13 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: gulian]
doyall Offline
Loc: LA (Lower Alabama)
Originally Posted By: gulian
Wouldn't the Mobil filter void the warranty ...
Why?
#2419589 - 10/29/11 11:21 AM Re: Need advice,2012 Chevy Impala 3.6 [Re: rjh245]
MuzzleFlash40 Offline
Loc: Ohio
QSUD is dexos approved and is a fine oil!
15 Ram Big Horn 4x4 5.7-22k
DuraMAX Syn 5w20 & Mopar
16 Santa Fe Sport AWD 2.4-30k
Cam2 SynBlend 5w20 & OEM
Page 1 of 2 1 2 >
