'88 Caddy Brougham - dark oil + lifters noise
by momo
06/29/16 02:57 AM
Which Oil
by Jamn
06/29/16 02:11 AM
Oil for Binding Foundry Sand
by smw
06/29/16 01:38 AM
Found a good high zinc breakin oil
by 1977c10phxdriver
06/29/16 01:12 AM
What is this radio modulating sound?
by Pontual
06/29/16 01:00 AM
The reason brake fluid can be Dot 3&4 - Viscosity!
by CharlieBauer
06/29/16 12:56 AM
No injector pulse, '92 Prelude, F20B, GSR ECM
by redhat
06/29/16 12:02 AM
Finding #1 Cylinder
by motorguy222
06/28/16 11:31 PM
Sure Filter 2821A C&P
by funflyer
06/28/16 11:27 PM
Can Kies save multiple phone info?
by daves66nova
06/28/16 11:25 PM
Tie-Rod Brands? AcDelco, B&A, Mevotech, MOOG
by Mr_Accord
06/28/16 10:23 PM
Engineer and Frog
by Koop
06/28/16 09:05 PM
dougsangster, CrazyCalvinW, mal86, smw, Crobinson16
58311 Registered Users
21 registered (Bookmaker, dec219644, Darris, alcyon, Deltona_Dave, 2 invisible), 828 Guests and 12 Spiders online.
58311 Members
66 Forums
250966 Topics
Page 1 of 4 1 2 3 4 >
#2160501 - 02/04/11 03:52 AM Varnish in Honda 3.5 VTEC
Trav Offline
Loc: MA, Mittelfranken.de
How many times have we heard here that "varnish is only a cosmetic stain"? I was even told i had a fetish for believing it can be a nightmare for modern high tech engines.
Seeing as i have a 2005 Honda here with an all to common varnish/sludge issue that basically disables 3 cylinders when the VTEC valve sticks i decided to document it and share it here.
Here is the valve itself,we removed it earlier,cleaned the screen only and reinstalled.We ran Kreen through the engine and the valve did begin to move.It still looks bad but it is much better than before.
This is the small filter that gets clogged.This is very small and takes very little to stop the flow of oil.
The solenoid that gets also stuck when varnished.
The passages in the head.
This is proof that varnish is anything but cosmetic in some if not most modern engines.Most modern engines use some sort of oil fed actuated valves or tensioners to perform different jobs,while the effects may not be as extreme as in this engine the varnish can definitely stick some important components.
This engine had documented 7500 mi OCI with a major brand of synthetic oil, (i will not disclose the brand as it maybe taken as a bash,it is not.The issue here is with the engine design)The PCV had been serviced.
With these engines the question has to be is 7500 to long?
The oil filter had gone into bypass and dumped a lot of junk into the passages.
More passage pics to follow,we will be doing a pan drop for inspection only and will post pics.
#2160502 - 02/04/11 04:05 AM Re: Varnish in Honda 3.5 VTEC [Re: Trav]
190E26FTW Offline
Loc: Los Angeles, CA
dang. keep us posted.
#2160503 - 02/04/11 04:30 AM Re: Varnish in Honda 3.5 VTEC [Re: 190E26FTW]
TTK Offline
Loc: TN
How many miles on this engine? Was 5w-20 used in this engine?
Edited by TTK (02/04/11 04:33 AM)
2010 Volvo V70-3.2
Current Fill:Mobil 1 AFE 0w-30
2014 Subaru Forester, 0w-20 Castrol Magnatec
2001 Chevrolet Prism
NAPA Synthetic 5w-30
#2160510 - 02/04/11 05:06 AM Re: Varnish in Honda 3.5 VTEC [Re: Trav]
Unearthed Offline
Loc: USA
Wow 7500mi OCIs with syn was not sufficient? Why would the filter go into bypass so soon? Any idea on filter brand or if they were left on for 15k at a time?
2015 Civic Si
2014 VW Sportwagen
2003 Suzuki vz800
#2160534 - 02/04/11 05:56 AM Re: Varnish in Honda 3.5 VTEC [Re: Trav]
demarpaint Offline
Loc: NY
Wow, imagine the guys who blindly extend OCI's to 25,000+ miles or a year because the oil company said they could. Yikes!
God Bless Our Troops
#2160541 - 02/04/11 06:09 AM Re: Varnish in Honda 3.5 VTEC [Re: Trav]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
I guess one could say that's not varnish, and more like serious build up. These Honda engines are way harder on oil than people have assumed - be the people Amsoil or BITOGians. I believe the major cause is fuel in the oil and fairly high combustion temperatures.
Just as a seat of the pants thing, my wife's 3.5 V6 comes up to temp, like NOW. The temperature stabilizes just fine, but it gets hot and gets hot quickly.
#2160547 - 02/04/11 06:21 AM Re: Varnish in Honda 3.5 VTEC [Re: TTK]
Trav Offline
82K on this engine,soccer mom van,short trips around town but lots of them.Severe service at its worst.
Yes 5w-20 but after we get it cleaned up Mobil 1 ESP 5w-30 will be used,this oil is recommended for this engine in the rest of the world.Its obvious the oil didn't hold up well in this application.
Look at the following pictures and you decide for yourself if it was sufficient.Oil filter was changed every OCI with OEM Honda.As far as i can tell there were a lot of deposits and minor sludge deposits that probably clogged the small oil filter sending it into bypass.Varnish and particulate matter appear to be the main culprit here
Oil filter mount.
Engine where mount bolts on.
Gaskets.Note the new one has an extra filter added. It makes me wonder if Honda is trying to address this issue with modified parts without openly admitting there is an issue.
Parts clean and ready to be reinstalled.
Oil pan drop pics to follow over the weekend.
Not the areas the Kreen did mange to get through to are beginning to come clean.It did in fact get oil back into the valve and got it functioning again.
#2160552 - 02/04/11 06:25 AM Re: Varnish in Honda 3.5 VTEC [Re: Trav]
Chris Meutsch Offline
Loc: Cincinnati
Hmmm. I have the same type of driving wife with the same engine, but a 2008. We got it with 28k already used. I changed the dealer bulk to PP 5w20 and was planning 7500 OCI's. Perhaps I should shorten to 6k? I don't mind if it prevents this junk from happening.
"maybe maroonish? It could be moronish not to change it."
---Egg_Head, 6/21/16
#2160556 - 02/04/11 06:31 AM Re: Varnish in Honda 3.5 VTEC [Re: Trav]
mpvue Offline
Loc: Easton, PA
OH NOES! a HONDA has issues??? say it isn't so!
"I am preety smart guy 3.5 or higher in all my college class's and I have no clue any more".
-JohnBrowning
#2160557 - 02/04/11 06:37 AM Re: Varnish in Honda 3.5 VTEC [Re: Pablo]
Trav Offline
There is build up for sure but the amount of varnish is incredible.IMHO varnish is a precursor to the formation of sludge.Again that's just my opinion.
I have done work to a few of these engines in Germany for friends of mine that were using the ESP for 15,000 KM (9K mi) OCI and none showed this kind of build up.
Oil quality issues along with an engine design issue?
I don't know but i would like to find the answer.
After doing so many of these and Nissan VQ engines i have learned a lot about them and what makes them tick but there sure does seem to be some lube related issues with both that causes all sorts of strange engine codes.
On the Honda the engine will drop to 3 cylinders,throw misfire codes all over the place and act like a plugged cat basically undrivable.
I pulled the injectors out of this one not to long ago and ran them on my flow bench,all were tight with no leaker's and a all 6 had a nice spray pattern.Fuel dilution doesn't seem to be a major issue on this particular engine anyway.
#2160560 - 02/04/11 06:39 AM Re: Varnish in Honda 3.5 VTEC [Re: Trav]
demarpaint Offline
Loc: NY
I don't think the 20 grade oil was to blame here. I think a shorter OCI is the ticket. It is obvious the mfg suggested OCI is not working! Based on what you're saying it looks like a design flaw, plain and simple. I wonder if a pint of MMO for the last 1000 miles of the OCI would have helped? Or a yearly treatment of MMO for a shorter winter OCI? Or an annual treatment of Kreen would have helped? My bet is yes. Hindsight is 20/20.
Nice job cleaning up that baby! Great pictures and report, thanks for posting!
#2160561 - 02/04/11 06:41 AM Re: Varnish in Honda 3.5 VTEC [Re: Chris Meutsch]
Trav Offline
My brother had these identical issues also at the 80k mark.
I would definitely run a shorter OCI maybe even 5k with a high quality filter.
Keep an eye out in the oil filler,if it begins to look dark brownish in there shorten the OCI dramatically until its clean.
Its been my experience that once this stuff gets a hold in the engine its a very slippery slope.
#2160562 - 02/04/11 06:47 AM Re: Varnish in Honda 3.5 VTEC [Re: Trav]
btanchors Offline
Loc: Herndon, VA
This thread makes me a bit nervous - as I've been doing 10K OCIs on a vehicle that sees a similar type of service.
One question - Can a Blackstone UOA detect when the oil is in a state likely to begin the formation of varnish?
My first thought was TBN and Total Solids, but then I suspect Total Solids wouldn't go up appreciably until sludge would begin to form. I suspect varnish would begin to form well before that.
#2160566 - 02/04/11 06:51 AM Re: Varnish in Honda 3.5 VTEC [Re: Trav]
Vikas Offline
Loc: NorthEast
Trav,
There are zillions of these Odysseys on the road. They have a list of "pattern failures" but this one is NOT one of them. I follow dedicated forum for Odyssey regularly and to best of my knowledge I do not see this problem being reported often enough.
There is something unique about this particular sample.
- Vikas
#2160571 - 02/04/11 06:59 AM Re: Varnish in Honda 3.5 VTEC [Re: btanchors]
demarpaint Offline
Loc: NY
I doubt a B_S report can detect varnish. It would have been interesting to see a lab report of the oil taken from that engine to see if anything was suspect, and if there is a way to detect varnish. I always viewed heavy varnish as a primer for sludge. Light staining or discoloration is not an issue. I always felt varnish was the signal to start cleanup before its to late. This just proves that. My bet is a UOA would have shown that oil to be OK for more use.
