Originally Posted By: sayjac
Quote:
The leaf spring is scam because its not a spring at all. The "spring" does not stretch or recoil at all. The oil pressure deformed the leaf spring and left my filter in bypass mode probably through most of the 5K miles.
Got any pics? A scam huh? Oh fyi, it's not a leaf spring. The leaf spring (pictured above) in the dome is what holds the filter core and adbv to the base.
Did you send the filter back to Purolator for inspection? Very responsive CS department as shown in this forum many times.
I've used many Puro's and with 45 adator style bypass and cut them open and never had an issue. It sits in a recess so the OP's explanation plus camera angle seems a likely explanation. If the OP's bypass was struck open he could easily tell and view light through the centertube. I think I'll believe the OP when he says it's not deformed. But then again he couldn't tell (nor I) that it looked like it had been in service for over a year. Oh, that's right it was only 5 months.
Like the OP said, just an illusion. Or, since it is a spring, there probably is a space between it and the valve so that it can maintain tension. "Posters" like you make me wonder why I post at all. A couple of posts asking about a possible issue and you gotta stick your chest out and get all defensive. Whatever...!!!
