5w-40 synthetic vs 15w-40 synthetic
by mbacfp
06/27/16 01:27 PM
SCAM!Anyone renting their water heater tank?
by KrisZ
06/27/16 01:16 PM
Donaldson PowerCore as HEPA filter?
by PeterPolyol
06/27/16 01:13 PM
Clearance oversized filters for M20x1.5 w/bypass
by PeterPolyol
06/27/16 01:05 PM
Prestone vs. DEX-COOL Concentrate
by Ramblejam
06/27/16 12:54 PM
Severe service and OEM oil Filters
by Tech819
06/27/16 12:46 PM
ContiTech Pro Series timing belt kit 2009 Galant
by Ruturaj
06/27/16 12:25 PM
Bogus Coolant Test! - did Pat Goss make a mistake?
by i_hate_autofraud
06/27/16 11:57 AM
The "zero posters"
by OVERKILL
06/27/16 11:57 AM
Removing "Holder?" From Dash
by coopns
06/27/16 11:53 AM
Concrete Cleaners
by dkryan
06/27/16 11:45 AM
What makes CVTF?
by horse123
06/27/16 10:40 AM
karpouzi, Tapan, shindery, Josh_Westwood, Brogan
58283 Registered Users
89 registered (69GTX, Al, 4WD, 901Memphis, AlaskaMike, 360kid, 7 invisible), 2133 Guests and 11 Spiders online.
58283 Members
66 Forums
250883 Topics
#1944187 - 07/06/10 11:27 AM Oil filter for a 25HP Kohler?
deeter16317 Offline
Loc: SE, PA
What would be the Wix alternative to the Kohler filter on a newer engine??
Thanks!
2004.5 Dodge 2500 Cummins
#1944229 - 07/06/10 12:09 PM Re: Oil filter for a 25HP Kohler? [Re: deeter16317]
nutsbolts Offline
Loc: princeton fl
I looked and found the following equivalents:
Fleetguard LF3335
Purolator L10241
Wix 51348
Here are the Wix Specs:
Part Number: 51348
UPC Number: 765809513488
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Gasket Diameter (attached)
O.D. 2.734
I.D. 2.430
Edited by nutsbolts (07/06/10 12:10 PM)
#1944263 - 07/06/10 12:46 PM Re: Oil filter for a 25HP Kohler? [Re: nutsbolts]
deeter16317 Offline
Loc: SE, PA
Thanks!
I didn't have anything to start with...so cross-referencing it was impossible.
#1944648 - 07/06/10 07:48 PM Re: Oil filter for a 25HP Kohler? [Re: deeter16317]
jdh Offline
Loc: kentucky
fwiw i use a supertech 3614 and it is a direct replacement for the longer kohler filter
#1945026 - 07/07/10 06:19 AM Re: Oil filter for a 25HP Kohler? [Re: jdh]
deeter16317 Offline
Loc: SE, PA
Cool...I'll look one of those up.
#1946659 - 07/08/10 11:58 AM Re: Oil filter for a 25HP Kohler? [Re: deeter16317]
deeter16317 Offline
Loc: SE, PA
That's funny...the same filter used on about every make of car manufacturer too! At least it should always be supported.
#1947693 - 07/09/10 10:59 AM Re: Oil filter for a 25HP Kohler? [Re: deeter16317]
mrausch82 Offline
Loc: Newark, Delaware
I've been running the Purolator Pure One on my Kohler since new 2-1/2 years ago with no trouble. The Purolator is cheaper I believe.
1983 Volvo 242DL
1984 Volvo 242DL
1987 Volvo 245DL
1988 Chevy S10
1995 Chevy 2500 turbo diesel
2010 Volvo XC90
#1947758 - 07/09/10 12:11 PM Re: Oil filter for a 25HP Kohler? [Re: mrausch82]
JTK Offline
Loc: Buffalo, NY
I ran one size on my Command 20; Motorcraft FL400 or the Napa, Carquest and Supertech equivalent. Currently have a ST3600 on my Kohler Courage 20 twin. Same basic block dimensions as the Command. You do not have to worry about exotic or hard to find sizes for these engines. FL400/ST3600 is all you need and is the largest, safe/comfortable fit.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#1948306 - 07/09/10 09:08 PM Re: Oil filter for a 25HP Kohler? [Re: JTK]
Mr_Joe Offline
Loc: Wisconsin
I'm going ST 3600 on my Cub Cadet Kohler next change.
#1949128 - 07/10/10 05:27 PM Re: Oil filter for a 25HP Kohler? [Re: Mr_Joe]
whitearrow Offline
Loc: philadelphia,ms
i use the purolator classic white can on my kohler 16 hp command with good results. the classic is also $3 vs the kohler $13.
2005 toyota camry xle on syntec 5w-30
2010 toyota tundra dc 4x4 5.7 liter V8 on toyota 0w-20 synthetic
2010 toyota highlander on toyota 0w-20 synthetic
