Don't discount coal for a long while yet...
by Shannow
8 minutes 52 seconds ago
Decent Wireless Computer Headset?
by 99Saturn
Yesterday at 11:41 PM
Need Fuel Pump Assembly for Camry
by Nick1994
Yesterday at 11:36 PM
2015 Accord V6 VCM engine UOA 36,680 mi / 9812 OCI
by TNM1982
Yesterday at 10:55 PM
Why did Toyota recommend a winter and summer oil?
by BrianApp
Yesterday at 10:00 PM
Fram TG 7317 6k miles
by bbhero
Yesterday at 09:57 PM
Sta-Lube Moly-Graph Grease
by JHZR2
Yesterday at 09:20 PM
Dead battery locks me out of Altima!
by Tom NJ
Yesterday at 08:56 PM
Second lawn mower blade
by greasegunn
Yesterday at 08:11 PM
Echo weed trimmer - carb issue?
by ryan2022
Yesterday at 07:13 PM
Reviving Old Hard Rubber Experiment
by sleddriver
Yesterday at 04:47 PM
Where do pets go?
by Whitewolf
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
18 registered (-SyN-, EchoTech1945, Drosselmier, clinebarger, chrisri, DavidZ28), 787 Guests and 10 Spiders online.
58272 Members
66 Forums
250819 Topics
#1788283 - 02/20/10 02:26 AM Transmission service on "new" 2000 Buick Century
oilmaven Offline
Loc: Northern Michigan
Hi all...need some advice here. I just picked up a 2000 Buick Century Limited with 87k for my sister. The car is an original owner vehicle...middle aged couple from Florida (no rust!). The vehicle has been pretty well maintained (including replacement of the LIM at 72,000 miles)and the engine is quiet as a church mouse...interior is mint and it has new tires. I'm taking it to my mechanic this weekend to have it "gone over" and intend to do a pan drop service for the transmission. From what I'm reading on here, some believe there's little advantage to adding a synthetic fluid for this type of service? I really want to replace the pan filter and limited $$$ preclude a flush AND pan service. My plan was to replace the 7 quarts or so that this will drain with Amsoil or Mobil 1 ATF. Is there any advantage to using either of these synthetic ATF fluids over DexIII if I'm not doing a total exchange?
2010 Suzuki Kizashi-Pennzoil Platinum Pureplus 5W30
2013 Toyota Prius-Pennzoil Platinum 0W20
#1788286 - 02/20/10 03:02 AM Re: Transmission service on "new" 2000 Buick Century [Re: oilmaven]
JustinH Offline
Loc: Texas
I would use a fluid that meets the specs in the manual.
In a front drive car like this, I would take it to a shop with a fluid exchange machine and let them flush the transmission.
I would also drop the pan, and replace the filter. Have them clean the pan real well also.
Take it to an honest shop with a flush machine. Plan on spending about 100 dollars.
You don't need to use the amsoil or mobil1 in this application.
'10 Toyota Rav4 Sport
'08 Toyota Matrix
#1788315 - 02/20/10 06:05 AM Re: Transmission service on "new" 2000 Buick Century [Re: JustinH]
unDummy Offline
Loc: RI
Use DexronVI if budget is tight.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#1788321 - 02/20/10 06:31 AM Re: Transmission service on "new" 2000 Buick Century [Re: unDummy]
lord kelvin Offline
Loc: Pennsylvania
Recent experience with a 2001 Olds Alero:
I'm relaying my experience because I'm pretty sure these cars have the same transmission. Bought this car which just turned 100Kmiles for my kid (XMAS present). I dropped the pan and changed the filter. As you say, it takes 7qts of fluid. I used Pennzoil Multi-Vehicle ATF. I chose that fluid because I use it in my Windstar and the bottle states it can be used in DEX-III applications. RESULT: it changed the shift-characteristics. It takes a tad longer to shift, versus being very quick and precise with the old fluid. Once it warms up, I plan on trying a different fluid....likly a true DEX-III fluid since that was the original fill. Some will say to use DEX-VI, but if you change the fluid every 25kmiles, does it matter? I doubt it.
Hope this helps.
#1788438 - 02/20/10 09:24 AM Re: Transmission service on "new" 2000 Buick Century [Re: lord kelvin]
oilmaven Offline
Thanks, guys...think I'll pick up some Dex-VI (probably ST at Wally World) and refill with that after the pan drop and filter replacement. I believe from past experience that it's important to replace the filters on these units...hence the pan drop (also don't know the history of this trans...no indication that it's ever been serviced). The shops around here only use Dex-III in their flush (or "exchange") machines and want a fortune for the service. I think we should be OK with this method...all the input much appreciated.
#1788511 - 02/20/10 10:42 AM Re: Transmission service on "new" 2000 Buick Century [Re: oilmaven]
pbm Offline
Loc: New York
I have an 02' Century and I run Mobil 1 ATF w/ Lubegard Red.
The A/T shifts beautifully. I like the synthetic because it allows me to go longer between changes. I changed the OE fluid at 36K and then replaced that fluid at 96K (a 60K interval). I now have 114K and plan on changing it again at approx. 160K.
I would probably use 'dino' fluid if the pan had a drain plug but dropping the pan is a PITA so hence I use synthetic.
PS: The Century has a 4T65E. I think the Alero has a 4T40.
#1788550 - 02/20/10 11:41 AM Re: Transmission service on "new" 2000 Buick Century [Re: pbm]
oilmaven Offline
pbm...Did you do a flush each time WITHOUT dropping the pan and changing the filter? I intend to add a bottle of Lubegard Red regardless of the fluid I use...been using it in ALL my transmissions (imports and domestics) at service time and never had a trans issue. Regardless of others opinions, I'm convinced it's good stuff.
#1788676 - 02/20/10 01:59 PM Re: Transmission service on "new" 2000 Buick Century [Re: oilmaven]
mechanicx Offline
Loc: Ohio
Yeah I would go with Dex VI approved. I don't think I'd bother with the Lubeguard but that's just me.
#1788682 - 02/20/10 02:06 PM Re: Transmission service on "new" 2000 Buick Century [Re: mechanicx]
JTK Offline
Loc: Buffalo, NY
That's a 4T65E trans in that Century. Very reliable, long lasting units. Any Dex/Merc universal ATF for it. Those Century's sure do ride nice. Quiet and Buick smooth.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#1789121 - 02/20/10 09:57 PM Re: Transmission service on "new" 2000 Buick Century [Re: oilmaven]
pbm Offline
Loc: New York
I've never done a flush. The first time I removed the pan,changed the filter, added a few extra magnets and refilled. I was able to get almost 8 of the 10 quarts out this way. The second time I put a long piece of tubing down the dipstick hole and siphoned out most of the fluid before dropping the pan and cleaning the magnets and replacing the fluid. It was a lot less messy removing the nearly empty pan.
I am also a believer in LG red and have used it in all of my trannies. I have never had a tranny go out,TG. LG red is probably overkill when using full synthetic fluid but I think it is a great addition to Dex III or Honda Z1.
