Further to an earlier post I started about Saturn SL2 Oil Advice, I thought I would follow-up with Performana Lubricants reply to my inquiry:
Hi Mr. Raso,
I am responding to the questions posed in your e-mail of March 4th.
The Emission Cleaning Kit is a three part service kit that is recommended every 12 months or 25,000 km. This kit has been developed to help reduce harmful emissions caused by carbon contamination in the fuel delivery system, intake valves, combustion chamber and compression rings. The process (which includes an oil change) is as follows.
Step One: The MOTOR FLUSH is added to the dirty oil. The engine is run for 10 Minutes and the oil is then drained. This step removes sludge contaminants on the oil ring and carbon deposits from the compression rings. It also removes harmful sludge and varnish that builds up in oil passages and the crankcase ventilation system.
Step Two: The OIL TREATMENT is added to the clean oil. This step adds a number of benefits including enhanced oil "pump-ability" at engine start-up, neutralizes harmful crankcase acids and improved engine performance by reducing friction. To answer your question regarding the benefits when added to synthetic oil. I do not personally believe that we can improve on the many benefits that full synthetic oils have to offer. I absolutely recommend our product to improve the performance of any and all multi-grade and semi-synthetic oils, but not full synthetic.
Step Three: The FUEL SYSTEM SERVICE is added to the fuel. This product is engineered as a fuel dryer, and when used on a regular basis (every 10,000 km), will maintain optimum fuel delivery by keeping the fuel rail and injectors clean and will retard the build up of carbon deposits in the combustion chamber.
This process will reduce oil consumption because clean valves seat better, clean rings expand to reduce oil blow by and valve stem oil seals that remain in good condition reduce oil seepage into the combustion chamber. These are the three main causes for oil consumption.
I hope that I have answered your questions to you satisfaction and I thank you and your parents for your interest in the Performa products. Please feel free to contact me should you have any additional questions.
Guy R. Smith
President
Hi Mr. Raso,
Guy R. Smith
President
