Originally Posted By: PW01
Originally Posted By: john1944
Yes I did. If I get a reply, I will post it here. But I wanted to also see what other sources said.
Did you hear back from the folks at Mobil 1
This is the correspondence I have had so far with Mobil 1 regarding their 0W-30 not being rated ACEA A5:
>> -----Original Message-----
>> From: ExxonMobil
>> Sent: Tue, 10 Feb 2009 11:14 am
>> Subject: Re: 4377 (WJF)
>> >>> Thank you for your inquiry. ACEA is European Oil Sequences for
>>> Service-Fill Oils. Wondering why your are asking about ACEA
>>> specifications, does your vehicle require an ACEA specification?
>> My vehicle does not require an ACEA specification. I just know that
>> when oil manufacturers can meet ACEA specs, they always proudly show
>> it - just check any of your Mobil 1 PDSs. So it would follow that if
>> they cannot, for whatever reason, they do not. I was just wondering
>> why Mobil 0W-30 does not apparently meet ACEA A5 and Mobil 1 5W-30 does.
>> John
> Thank you for your inquiry. ACEA is European Automobile Manufacturers
> Association. Its just that we may not purse ACEA approvals for a Mobil 1
> product that is not marketed in Europe. ILSAC and API have very demanding
> requirements also.
> Technical Support Engineer (WJF)
