WiFi Extenders
by GGorman04
07/30/16 09:54 AM
Need Help getting on track/ 07 Honda Pilot
by 07Piloteer
07/30/16 09:23 AM
Installing A Magnefine Filter
by -SyN-
07/30/16 09:22 AM
Delo 400 Bottles LH?
by AirgunSavant
07/30/16 09:14 AM
wheel bearing grease
by meborder
07/30/16 06:59 AM
My car audio build thread
by dan_erickson
07/30/16 06:08 AM
Pegasus PS737 Cut Open. Unknown Mileage / Oil
by Farmer
07/30/16 05:45 AM
Napa Gold 1372, 4.5 Months, 8500KM.
by Farmer
07/30/16 05:38 AM
lubriplate 1200-2
by buffalobob
07/30/16 02:49 AM
How do you politely say no to people?
by motor_oil_madman
07/30/16 12:39 AM
To change or not?
by ram_man
07/29/16 11:55 PM
Nozzle Flow Versus Pressure/Viscosity
by Shannow
07/29/16 11:20 PM
RM53119, Ctanke, jractk, LatitudeDancer, AKN
58647 Registered Users
76 registered (AirgunSavant, Atesz792, 97f150, aquariuscsm, andyd, AIRJAC3, 7 invisible), 1989 Guests and 7 Spiders online.
58647 Members
66 Forums
252440 Topics
Page 1 of 2 1 2 >
#1000682 - 10/01/07 07:22 AM ATF or PS Fluid for Power Steering?
erogers Offline
Loc: Land of Lincoln
Hello, all. I have a 1994 T-Bird and the manual says I can either use Power Steering fluid or Type F ATF in my power steering unit. I've always used Power Steering Fluid (usually Valvoline), but am wondering if there would be any advantage to using the Type F. Any thoughts?
'05 VW Passat TDI: Amsoil European Car Formula 5W-40
'89 Jaguar XJ6: Mobil 1 High Mileage 10W-40
'94 T-Bird LX 4.6 - RIP 1/10/12
#1000683 - 10/01/07 07:28 AM Re: ATF or PS Fluid for Power Steering? [Re: erogers]
askani79705 Offline
Loc: midland tx
No stick with the Valvoline,Preferably Max Life
2014 Subaru Forester Wix 57055 0w20 QSUD.
97 Ford 150 MC FL820s Mobil High Mileage 5W30
#1000684 - 10/01/07 08:22 AM Re: ATF or PS Fluid for Power Steering? [Re: askani79705]
erogers Offline
One of the reasons I asked is that on my other vehicle, that only calls for Dexron III for its power steering fluid, the fluid stays fresh-looking and red, while the power steering fluid in my T-Bird (Valvoline SynPower) turns a grayish-black almost instantly, even after I drain and refill. I'm wondering if the ATF somehow lasts longer or keeps the system cleaner. I doubt I would notice any improvement either way.
#1000685 - 10/01/07 09:09 PM Re: ATF or PS Fluid for Power Steering? [Re: erogers]
askani79705 Offline
Loc: midland tx
I don't know why it would do that.I do know we use Maxlife in the P/S in our Ford work trucks and it works great even in this West Tx heat.Of course you could always try the Type F it should be fine and probably cheaper.
#1000686 - 10/01/07 11:13 PM Re: ATF or PS Fluid for Power Steering? [Re: askani79705]
erogers Offline
Maybe I'll give the Type F a try just for the heck of it. Once I do, I'll be sure to post the results. At the very least, it should be a cheaper alternative for doing a few flushes before returning to the Maxlife PS fluid. Maybe all the system needs is a few flushes in a row.
#1000687 - 10/02/07 12:18 AM Re: ATF or PS Fluid for Power Steering? [Re: erogers]
brianl703 Offline
Loc: Manassas, VA
You can use DexIII/Mercon in place of Type F in that power steering system. You can also use Mercon V.
#1000688 - 10/02/07 03:56 AM Re: ATF or PS Fluid for Power Steering? [Re: brianl703]
Whitewolf Offline
Loc: MI, USA
Use what is recommended the seals and hoses have to be tested with approved fluids.
My definition of an expert in any field is a person who knows enough about what's really going on to be scared.
~ PJ Plauger
#1000689 - 10/02/07 03:58 AM Re: ATF or PS Fluid for Power Steering? [Re: Whitewolf]
rsylvstr Offline
Loc: Oneida County, NY
My 1992 Galant leaks like crazy....and it's not worth replacing the rack.
is there anything cheap that i can use instead of ATF?
Rob / Doc Master Chief
2001 F150 SCrew Lariat 4X4 5.4L, 4R70W, LS 9.75" 3.55
2012 Altima SL that my wife doesn't want me to touch.
#1000690 - 10/02/07 04:57 AM Re: ATF or PS Fluid for Power Steering? [Re: Whitewolf]
erogers Offline
I just finished flushing my power steering system with one quart of fresh power steering fluid and two quarts of Castrol Type F. Then, I filled the system with more fresh Type F. I took it for a drive afterwards (about eight miles), and did not notice any difference in performance. The noise level of the power steering unit is virtually silent, just like before. The fluid has remained nice and bright red. We'll see how it looks in a few days. The yellow-clear PS fluid would turn dark almost instantly, so hopefully there will be an improvement in that area.
#1000691 - 10/02/07 08:16 AM Re: ATF or PS Fluid for Power Steering? [Re: Whitewolf]
brianl703 Offline
Loc: Manassas, VA
I don't use Type F in Ford power steering systems anymore, preferring instead to use Mercon or Mercon V, and have never had an issue with leaks. Using Mercon seems to have fixed the cold-weather stiffness my 1988 Mustang GT had.
#1000692 - 10/02/07 03:11 PM Re: ATF or PS Fluid for Power Steering? [Re: brianl703]
wiswind Offline
Loc: Wisconsin
Your manual may be telling you to use the Type F ATF or a specific Motorcraft "power steering" fluid, that is a type F ATF.
My manual ('96 windstar) gives a specification number.
I have Redline Synthetic Power Steering Fluid in mine.
I found the Redline by taking the FORD specification number and doing a Yahoo search on it.
As stated, you should be fine with the Mercon / Mercon V fluid......which Mobil 1 ATF is.....and is readily available.
Either of the ATF fluids that I mention will be great for cold weather, and the synthetic fluid will also give you improved heat tolerance.
#1000693 - 10/02/07 05:34 PM Re: ATF or PS Fluid for Power Steering? [Re: wiswind]
mazduh30 Offline
Loc: BC Canada
Check the owner's manual, or call the dealer to be sure. Also the amsoil site has a build list for vehicles which has all fluid recommedations.
#1000694 - 10/02/07 05:39 PM Re: ATF or PS Fluid for Power Steering? [Re: wiswind]
unDummy Offline
Loc: RI
Type-F is ancient. I too use Dex/Merc in those PSF systems. No seal issues either.
If you can't find type-F, various powershift and hydraulic fluids also meet the Type-F/G specs. Just read the label.
For those of you hung up on a spec, Amsoil ART, Redline Racing ATF, and Neo are some synthetic Type-F choices.
A siphon/refill doesn't remove all the old PSF. When switching to a 'clear' PSF, you will always have some of the old ATF in the system. This could be the reason why the new fluid discolors frequently. Practice a more frequent siphon/refill interval and the PSF will stay clean.
Neo, Redline, Royalpurple, Synlube....also make full synthetic PSFs compatible with most PSF systems.
#1000695 - 10/02/07 06:18 PM Re: ATF or PS Fluid for Power Steering? [Re: unDummy]
Big Jim Offline
Loc: Thousand Oaks, CA
I have used Dexron/Mercon in power steering system that called for Type F for DECADES. It is a superior fluid for poser steering use. I especially like Mobil 1 ATF for that application.
#1000696 - 10/03/07 12:49 AM Re: ATF or PS Fluid for Power Steering? [Re: Big Jim]
erogers Offline
For the record, my manual states:
"Use only power steering fluid that meets Ford's Specification for ESW-M2C33F, such as Ford's Premium Power Steering Fluid, E6AZ-19582-AA or equivalent"
On the Lubricant Specifications page it states:
"Power Steering (Pump Reservoir): Part No. XT-1-QF / Motorcraft Automatic Transmission Fluid - Type F - ESW-M2C33F"
Now, although you may be able to safely run a Dexron or Mercon fluid in this system, it does not say this anywhere in the manual. In fact, my transmission uses Mercon, but it specifically states Type F for the power steering. While at my local car parts store yesterday, I checked the back of the ATF bottles. The Dexron III/Mercon bottles did not have the ESW-M2C33-F specification on the bottle, but the Type F bottle did. They probably work interchangeably, but I feel safer using the specified product. YMMV, though.
Page 1 of 2 1 2 >
