1985 Nissan 300zx
Got it at about 135,000 miles. First year, Pennzoil oil and filters at local lube place at about 3k miles. Then Royal Purple, first at 10w-30 (at the local place, with pennzoil filters), then 20w-50 for racing purposes (at first with pennzoil filters, but got smart and started to use the Motorcraft FL-1A). Intervals were 3 months, probably 5-8k miles. Got sick of using that stuff (and stopped racing the car) so I used Mobil drive clean 10w-30 for a year. When I started to race the car again I switched to 10w-40. Did short OCI's, about 1500-2000 miles. Middle of last season I switched to Valvo VR1 20w-50 once the oil started to show that it was relatively clean. My OCI was 4-5 events (~1000 miles) Switched over to MaxLife 10w-30 for the ice racing season/winter (~2000-3000 miles). For this season I switched over to Mobil Delvac 1300 and Delco PF2 filters. If the oil analysis show well and the engine gets cleaned up a tad (well, alot with autoRX) I'll do extended OCI's with M1 SUV or Rotella T synthetic.
Odometer is broken, so I guestimate somewhere between 180k and 200k. I use no oil bewteen my changes.
Just bought a beater 1989 Honda Prelude w 150k. Don't know how much oil it burns as it has stripped drain plug threads so it leaks out the old, hardened rubber drain plug. Did a short 1k dino oil change and the oil came out filthy. Replaced hardened rubber drain plug with a new one (I will helicoil next OCI). I intend to run extended OCI's of 10k (still in the process of choosing the oil) on it once I'm done with autoRX. So far I'm 650 miles into it and the both the dipstick and oil filler cap are much cleaner.
[ March 21, 2004, 08:57 PM: Message edited by: Thomas Pyrek ]
