Hey guys,
Took my Z to the track last night. I am very dissapointed, to say the least. The best I could do was a [email protected]. The weather was warm (typical Texas weather for this time of the year), with temperatures in the high to mid 80s and more than 75% humidity.
I found out that the Z06 clutch in my car (stock) is a piece of junk. I did my burnouts to get the tires hot and sticky......big mistake! The tires were actually hooking up so good, that it made the clutch slip a lot. I tried different RPMs, all the way up to 3k.......the clutch wouldn't hold. I even powershifted to improve my times and the clutch once again gave up on me.
The last 2 runs were done without a burnout. The tires spun, but the clutch held much better.
Here is the summary:
Comments welcomed
The engine seemed to be running great. I had added ~3 oz of FP to ~ 9 gallons of fuel before going to the track. I had the usual and very noticeable pinging I always get in summertime......sometimes even winter. Weather definitely affected the times and MPHs. My stock clutch will survive last night's abuse.....as long as it doesn't have to put up with tires that hook. On the street, the clutch does pretty good.code:
60ft 1/4 ET 1/4 MPH
-2.13 13.45 104.97 --- Tires hooked/Clutch slipped/car bogged down big time
-2.18 13.52 105.68 --- Tires hooked/Clutch slipped/car bogged down big time
-2.25 14.07 103.78 --- Tires hooked/Clutch slipped/car bogged down big time
-2.18 13.38 106.33 --- Small burnout to clean tires/ Clutch held/Traction so so
-2.65 14.52 104.75 --- Small burnout to clean tires/ Clutch held/Traction was horrible
All time best ET.
-~2.10 12.99 108.38 --- Small burnout to clean tires/Clutch held/Traction so so.
Original 16" rims and Good Year 245/50/16.
Now running 17" SS rims with Summitomo 275/40/17. Weather much better; in the 60s and lower humidity (~50-60%)
All time best MPH
-~2.10 13.00 109.68 --- Small burnout to clean tires/Clutch held/Traction so so.
Now running 17" SS rims with Summitomo 275/40/17. Weather much better; in the 70s and lower humidity (~50-60%)
Only addition was Hooker cat-back
Comments welcomed
