Originally Posted By: crazyoildude
Let me ask You a question.. Can you say and be 100% sure that the louvered filters you use on your fleet are always filtering and not in bypass some or most of the time? Don't forget the cold winters and some of the high flow oil pumps..
This is going to be good...
Im not even going to mention the louvers that are not opened all the way or the louvers that go in two directions ..
Cold winters and bypass are only an issue during warm up and any filter, regardless of design, would have this issue.
Motorking has mentioned in the past that engineers don't know how often a filter goes into bypass.
Even if a filter goes into bypass, dirty oil is better than no oil. After all, you are the one that preaches flow over filtration.
