Originally Posted By: crazyoildude
Bottom line is if the filters are restrictive they don"t flow as well and they are in bypass more often. Thats the way it works. It seems Some of these filter companies slow the flow so they don"t have to spend more on a better quality media.. Again like i said in my previous post im not a tribologist but i am not stupid either small holes equal less flow in many cases...Period!
Pretend its a perfect world and all the louvers are all punched correctly.. Can you answer the question now?
"Small holes will only equal less flow" if the restriction of the oil filter is so great that it makes the positive oil pump hit pressure relief. The whole concept of oil flow through an engine has to revolve around the positive displacement oil pump in the equation. ALL flow coming out of the oil pump WILL got through the engine as long as the oil pump is NOT in pressure relief. It's possible that not all of that flow will go through the filter's media and get filtered if the bypass valve is open, but in the end all of that oil will still go through the engine. People need to firmly grasp the whole functionality of the positive displacement oil pump to have meaningful discussions about supposed "flow restriction" through the oil filter.
In a perfect world where all louvers were well punched open, the center tube will have less pressure drop (meaning it flows better) than a center tube with holes. That's because the total area of all the louvers put together will likely be more than the total area of all the holes put together. The very basic/simple fact to remember is that MORE flow AREA means less restriction and less pressure drop given the same flow rate/volume.
Now IF the louvers were barely opened up, then it could cause the flow to become restricted which means the pressure drop across the center tube will be higher ... and yes that could cause the bypass valve to open quicker with more flow and/or more media contamination/loading.
There is no way filter designers are purposely adjusting louver opening to "control" the flow through the center tube to help protect the media. If the center tube is way less restrictive than the media (which it will be), then the only thing that protects the media from failure is the bypass valve, and of course the actual properties/strength of the media when there is a delta pressure put across it from the oil flow, as well as the physical spacing of the pleats - as we see with the Purolators that tear media.
