I think C and V70's are the facelift 850 after Ford took over. As Astro14 says, a bit quirky, and I wouldn't want to send my 850 in for all the things that need doing, I do it myself. My 850 sets a trans code and goes into limp mode every few days...I can set it right in a few seconds and reset the lamp with my phone. It's the PRN switch, it can be repaired or replaced, I'll fix it in the summer when I don't need it. A lot of stuff is like that, they can be repaired if you have the time to spend. Probably one of the easiest cambelts to replace - one bolt retains the camblet cover, and you don't need to remove the crank pulley. By the time you've done the job, the Honda Accord owner is still trying to get the crank pulley off.
It's a lot of car, my station wagon is cavernous, and my grandaughter loves the built in booster seat. My turbo goes like stink, and it's the best handling fwd car I've driven. But the ride is nowhere as good as my Mercedes.
