I've been having some strange brake behavior recently (long pedal travel before I get any real brake pressure, spongy pedal feel) and while I was under the car replacing CV axles, I noticed a small drop of brake fluid where the master cylinder mates with the brake booster. Do you think this behavior and the fluid could be indicative of a failing master cylinder? Does anyone know of any tests I could do to possibly corroborate my thought that it might need to be replaced? (The brake fluid level is fine and the brakes were bled when I replaced a wheel cylinder about 8 months ago, so I don't think it's an air issue unless the master cylinder is failing and air was introduced through the piston seal.)
