I have three cars. One of them is a track car. I have bled the brakes multiple times on all of them. On the track car when I slam the brakes on the circuit I need to push the pedal sooooo far. I noticed its the same way on the van and the RSX.
To my understanding I thought a brake pedal should only move a little bit and then it should be pressure based from there right? I have hard lines and SS rotors on the track car along with monoblock 6/4 piston Brembo rotors. What is compressing? Where is the fluid going when I press the brake pedal? I do understand the brake pedal needs to move to press the piston against the brake pad and to the rotor but shouldn't it stop at some point and go no further?
What am I missing here?
Yes, I properly bled the brakes and have bled the master as well as the ABS. Really all the cars I have driven ever (about 40) have a longish travel.
Side note: what is the deal with bleeding the brakes with the car on to get the booster to help out? I have heard of some guys doing this with the big 6 piston rotors as they are a pain to get all the air out and it seems to help.
2nd side note: What is the deal with bleeding the ABS by cracking the outlet lines one by one instead of using an OBD unit that moves the solenoids around? Is this another way or does this do absolutely nothing? One would think that if air could get out that way then it would travel down the line anyways and come out of the caliper eventually.
