Not much out there on Rislone Oil Treatment. It's been around forever, and it does have active ingredients that don't come back on a VOA like most cleaners you can run in your OCI.
From what I've found in the past it is a slower cleaner, most of it anecdotal evidence.
If the engine is relatively clean but has a few spots you are concerned about Rislone or MMO will probably be ok.
I have a truck with a tick and I've tried short OCIs and MMO in before. Right now I've got 1 quart of Rislone Oil Treatment in it. It still ticks.
However, for inermediate to serious sludge I'd go with just a High Mileage oil and short oil change intervals.
Low and slow is the way to go.
It's when you go fast that you clog a oil screen while away from home.
If you do want to go fast I recommend that you use a premium product.
I hear good things about Amsoil's engine flush, and great things about Kano Laboratories Kreen engine cleaner.
Above all else. If it comes with directions, FOLLOW THE DIRECTIONS
