I recently experienced grinding on my RR brake. Took it apart yesterday and the outer pad was fine, but the inner was down to the backing plate. (The LR caliper was fine; nice even wear on both pads.)
The car has 147k now, these pads have been on since 30k, I think. (I drive like a granny and have an M/T... I'm still on the original fronts!)
The slide pins look good as new, slid smoothly, still had grease, and uncompromised boots. The carrier does not have any visible issues where the tabs slide. The brakes were not dragging (I notice, since they were making such a racket.)
I went ahead and changed the pads/rotors. (AA house parts (Platinum Ceramic pads, house rotors); I needed the car up and running quickly... in retrospect I should have assumed I would need to do a brake job no matter what the problem was and mail-ordered better stuff, but I digress.) But obviously I don't want to grind through my new pads/rotors in a hurry, so it would be good to figure out what the problem was/is.
Any ideas? The only thing I can think of is to just assume it's got something to do with the slide pins and throw a rebuilt carrier at it. (The carrier includes and houses the slide pins.)
