Originally Posted By: Benito
Originally Posted By: Joe90_guy
It might be worth saying that the KO30 shear test isn't used on US PCMOs for the simple reason that the great majority of US oils would fail the test! The US differs greatly from Europe in that you use highly shearable 50 SSI VIs. These are very cheap and great for passing fuel economy tests but otherwise they are pretty useless.
I'm sure this situation only endures in the US because you change your oil so frequently.
You'd be surprised at what some people do with these cheap oils even in Euro vehicles. The following is not something I would do but it seems to work for the following poster. Maybe the narrow spread of 5w20 and the ensuing lack of VII is working for him too
Originally Posted By: HTSS_TR
I had my E430 FF drained at more than 13k miles, passed the oil life monitor by several hundreds miles.
The engine is running good at 170+k miles, it doesn't consume measurable oil between OCI's, even with much thinner oil such as PP 5W20.
One time I used the Mahle cartridge oil filter for 2 OCI's of 10k each, the filter condition after 20k miles was almost as new. The filter holder of my E430 is almost as clean as the one in your picture.
I think a good synthetic in an MB engine can lasted up to 15-20k miles under non-severe driving condition. Since the average speed in US is much slower than in European countries, most of the times we don't drive too fast and RPM on highway is usually below 2.5-3k.
I used PP 5W20 in my E430. The oil spec is A3/B3 and M1 0W40 is on 229.3-229.5. With PP 5W20 in crankcase I drove to Vegas in July 2008, got stuck at Death Valley for 3 hours with temperature above 120F. Engine was/is fine with PP 5W20.
If the oilhas an ACEA rating, it's likely formulated with the low shear viscosity improvers.
