Originally Posted By: ExMachina
Originally Posted By: MolaKule
ATF has a very low level of ZDDP as one of the many anti-oxidants, but not enough for anti-wear. ATF does however have about 600 ppm of a special phosphorous chemistry for anti-wear, but this chemistry is for AW protection of bearings and planetary gearing. ATF has very low levels of anti-rust, detergency, and dispercency chemistry NOT suited for internal combustion engines.
Thanks for the summary, ATF you'd think has some lubrication properties an engine could use. Anti-rust, detergency, dispersancy isn't going to matter over only 40 miles, too short a term.
The phosphorous AW additives in ATF are optimized for gears/bearings, yet an engine is at least similar in rolling/sliding contact regimes. .... I agree that ATF fluid is not anywhere near optimal for an engine, yet you seem to be overreacting here based on your lubrication reasons... An extended warranty for 3 years would be more fair, not engine replacement.
If you depend on your truck for either getting to or from work, or using it in your job, it would not be over reacting.
It is the responsibility of the dealership to properly train their personnel in the proper use of, application, and dispensing of lubricants.
Again, if the OP can prove ATF was placed in the engine, I think the dealership has a responsibility to properly rectify this situation.
