Originally Posted By: Propflux01
Originally Posted By: turtlevette
Convert it to e85 and enjoy way more power.
Not!! Ethanol has less BTU's per gallon than straight gasoline. More has to be used in combustion to achieve the same amount of power, hence why MPG is always less.
Here we go again with the ethanol misinformed.. YES - less BTU'S yes, but can run more timing and boost with the higher blends. IT IS NOT a simple BTU to BTU equation, tho... That is what we are talking about... Poor Man's premium when blended with E85 to like 35% alcohol... depending on application...
I'd like to hear a proper technical explanation of why e10 is bad for a turbo engine.
Not no food for fuel or no mandates. A non political tech explanation.
Yes, gets used twice... Once to make the ethanol (corn hootch... just like the shiners intended !! ) and again as corn gluten meal...
no waste there...
Of course not everyone knows this - so we hear about it everytime this "food for fuel" issue comes up....
BurrWinder
no waste there...
BurrWinder
