Originally Posted By: 2010_FX4
Originally Posted By: Dallas69
I won't buy one again.
Agree; it is not even worth it when there there are filters that have the security of wire backing on the media and are guaranteed for x miles. Speaking for myself, though the FRAM Ultras are a few dollars more, since I use them for at least 15K, the cost is probably less overall--not to mention the peace of mind and the time that I save by not changing every 5 or 7K.
Im glad you brought that up. The Fram Ultra really is the only logical choice.
Originally Posted By: ZeeOSix
Originally Posted By: jk_636
So we blamed the media, but that was debunked since all filters Don't fail.
If you'd keep up with all this, it's been said many times by many members that it's most likely 3 factor formula that causes the failures. The two most prominent are the brittle media in conjunction with very widely spaced pleats with a large V-spread. The force of the oil pushing on those particular pleats causes too much side stress at the ends where those pleats are potted into the end cap, and the result is that the brittle media ends up tearing. The 3rd and weakest factor is the usage of the filter over the OCI. Of course filters used during a cold harsh winter (thick oil) have to withstand more delta-p than those in the summer time.
What brittle media? I just cut one open and the media was plenty stiff. Just the same as any other manufacturer I have cut open and manipulated?
There is no brittle media. Perhaps it gets brittle after being in use for way to long (I.E. extended OCIS that the filter was never designed for) but first hand experience shows that the media is, in fact, just fine when used appropriately.
If the media was brittle, all filters made with the same media would tear. Not just the few on here.
Look at GM. All of their late model vehicles were defective and they all failed. That is direct cause and effect. You cannot say the same thing about Purolator (well you could, but it wouldn't make any sense.)
Bottom line: a couple filters tore under questionable circumstances, the BITOG community over reacted, now things are fine and people are starting to realize there is no cause for panic.
I like how you always try to down play it ... "a couple". I wouldn't call 60+ a "couple".
And just who are these people who "are stating to realize there is no cause for panic."? You think those so called people are out buying Purolators for their next oil change?
Just because people dont argue on this sub forum doesn't mean they dont exist. There are many more people that read these forums and understand this is all hogwash than you may realize.
Originally Posted By: Stewie
Oh yeah purolators never tear is the frampire in BITOG that make people believe that they have torn by ripping the media apart before posting pictures.
You will soon realize that people don't cut their canister filters open yet they put in some review without facts (CUTTING CANISTER OPEN) and review filter media for tears, uneven pleats or damage.
Im not even sure what you are trying to say here....
Originally Posted By: cptbarkey
Originally Posted By: FutureDoc
Only a misconception by amateur forum users trying to defy logic. In a world of winners and losers, there are some folks that DNF.
Originally Posted By: k1rod
In the photos you will see some groves cut in the filtering media and a burn mark or two on the metal end caps. This was where my grinder went a little too deep.
You can eat your humble sandwich any day friend.
What were the circumstances around this filter? How did this happen? I have not seen this photo before.
Originally Posted By: webfors
Cptbarkey. Your behaviour on this board with respect to this topic is the precise definition of a troll. Everyone sees this but you.
There have been others before you, and there will no doubt be others after you. We've seen it all before. I'll give credit where credit is due though, the troll is strong within you.
What makes him a troll? The fact that he has an opinion that is different than yours and he doesn't back down when others try and push him around?
I dont agree with everything he says, but he has a right to say it. It doesn't make him a troll.
