My 02 F-250 7.3 has really low miles, just under 29K at the moment. MY normal oil change is at 5K miles with Rotella 10-30 T-5.
If I install this Donaldson filter should I keep the 5K oil change interval and change the filter every other change or just run the oil longer than 5K.
This Donaldson filter is a gigantic filter, it will hold about 3 quarts or more of oil.
