Very surprised there is no High Mileage motorcycle oil on the market. Cant think of even one major player? There is many of older/vintage bikes out there.
Most bikes spec 10w40 - 20w50, which are thick oils to begin with. I doubt the slightly thicker formula would do nada. However, I wonder what the additives would do for the clutch?? That may be the reason no HM MC oils are available. Or, I may just be blabbering but that's my .02 cents.
Typical motorcycle oil is already on the heavier side and loaded with additives, which is kind of what an HM oil is, isn't it?
Most high mileage oils, especially Maxlife says it has additives that prevent further wear which I'm guessing wouldn't be good in a wet clutch situation
