Originally Posted By: Shannow
Originally Posted By: virginoil
So you are using a Toyota oil in your Honda hey.
Why not use a Honda Oil in Honda?
Probably because Porsche backspecced to 5W40...and Ford spec a 5W20
Still waiting on BMW and Mercedes to make the give shift in the use to 0w-20 in the USA and Europe. Perhaps their oils will be interchangeable as well.
Once these oils are well run in, do not use the vehicle for a couple of days , as the oil molecules have been pre-programmed and will give your engine free start up music to confirm the change.
This engine music could be possibly be confused with a harsh parts grinding noise, do not be alarmed as this process is in its early days, in the future the oil molecules will be programmed and will be able to belt out your favorite tune for you to sing along to.
This is not good, so you will need to choose your oils carefully, if you WANT an engine to be a like a deaf mute which cannot speak and cannot be heard throughout its entire operating life when in use or no matter how its be sitting idle.
