Al Thread starter Joined Jun 8, 2002 Messages 20,223 Location Elizabethtown, Pa Mar 31, 2015 #21 Originally Posted By: Jetronic did you use pure gasoline? No 10% ethanol
S SilverSurfer Joined Mar 30, 2015 Messages 13 Location Heartland, USA Apr 2, 2015 #22 Are you going to re-jet the carb? Adding oil will cause the engine to run lean since a carb meters by volume and the oil is displacing the fuel.
J Jetronic Joined Feb 27, 2009 Messages 9,324 Location down in the park Apr 2, 2015 #23 the oil in itself is also a fuel, so a low percentage won't matter
Al Thread starter Joined Jun 8, 2002 Messages 20,223 Location Elizabethtown, Pa Apr 2, 2015 #24 Originally Posted By: Jetronic the oil in itself is also a fuel, so a low percentage won't matter This
