Originally Posted By: HangFire
Originally Posted By: zzyzzx
Originally Posted By: Chris142
20 gallon minimum.bigger is always better
+2. Nobody ever wishes that they have bought a smaller air compressor.
Like someone above me, I have a 3hp, 8 gallon Harbor Freight compressor, and it's often inadequate. I bought it to use a small HVLP paint gun, and it works fine for that, and as a blow gun, and to inflate tires. It's inadequate for sand blasting.
Partly because it's not truly 3HP... unless it hooks up to 220V. You can't get 3HP out of 110V/15A. Just another lie.
That's true. So should I believe the state CFM on the plate, which IIRC is 5.6cfm @90 PSI ??? Yes it's a 120V single phase compressor.
My compressor would be very similar to this one:
http://www.harborfreight.com/8-gal-2-hp-125-psi-oil-lube-air-compressor-69667.html
I suspects that the specs on HP and air output for the above one are are probably what my older, similar one actually does, even though it says higher on mine.
