1999 Silverado (newer style). Has worked fine barring a intermittent short in the steering column easily remedied by adjusting the wheel slightly. Went to start truck after work and wont start. Dash lights functioning properly Voltage around the 12 mark. No response from the starter, no solenoid clicking nor any other noise other than listening to the normal relays in the side fuse box. Checked and swapped all fuses and relays that involve starter or ignition. Tore the top cover off steering wheel to wiggle the connection on the ignition switch that is a common failure point.
Any ideas? Truck is in a horrible spot to work on. I'd like to get it started and limp it to a garage somewhere. Can the key be turned to the "on" position, connect jumper cables to the starter, and then connect to battery until running?
Thanks in advance
Thanks in advance
