Make sure your heater is on high and at the hottest temp during the whole process. Not sure if your particular Accord has a coolant bleeder valve or not. My 2000 Accord has a air bleeder valve by the thermostat area which lets the air out.
If after you change the coolant you get a bouncing idle then you still have air trapped in the coolant, need to get the air out.
