On my Gen Coupe I have two oil temp senders. One is the OEM up in the head by the cam actuators. The other is just after the filter before the oil goes to the bearings.
There is noticeable surface related cooling as the weather gets cold as the oil going coming out of the sump is at least 15F cooler than the oil at the head. This can only be because of the surface cooling from the oil pan and other parts before the bearings. This is also after the oil goes through a coolant/oil heat exchanger the filter mounts too so that is adding heat at that point.
So I would say the filter can area does help cool. It may not be all that noticeable. If I drove this car more in the winter I would probably put some sort of insulation in the front and sides of the oil pan to help keep the oil temp up.
