Originally Posted By: sayjac
Main reason, if something filter related happens to the engine, filter warranty would not apply. Also, if under vehicle manufacturer warranty, same thing could be an issue. I'll add not a likely event, but needs to be noted.
In an oil related warranty claim the manufacturer would have to prove the filter caused the damage even if the filter is not on a cross-reference list. The manufacturer can not specify restrictions on parts substitutions except under very specific circumstances.......
Two separate warranties were being addressed in my quote. The first is the filter warranty which only applies to the spec'd filter. That means as said, if an engine failure is caused by the filter or even suspected, there is no coverage from the filter manufacturer. Said several times in this forum, first thing a filter manufacturer checks when a filter related claim occurs is for the correct filter application. Non spec filter used, filter warranty claim is denied. In the event of no vehicle warranty, this means the owner is on his own and likely not to collect a dime. That warranty is pretty cut and dried.
The second would be if there also a vehicle warranty in effect. While the dealer would have to prove the the non spec filter caused the engine damage/failure, using a non spec filter is a likely first step the dealer will look to blame. Even spec aftermarket filters frequently get blamed for engine issues by dealers. And, while the dealer/manufacturer would have to prove it, who has the deeper pockets to fight such a claim if it goes to court. Most times it's the dealer and vehicle manufacturer. Again, unlikely event but the OP asked for any considerations for not oversizing.
In the OP's case, when it comes to the 6607/14612 to the 7317/141610, I consider it more of a 'sensible upsize' as opposed to a major oversize. The latter size is ~1/2" longer and all the rest of the specs are the same. Same goes for their SAE thread counterparts the 4967/14476 to the 4386/14477. I'd upsize either of the small applications if room permitted.
This is, by far, the most important and critical topic for the thread. Simply put, this is about burden of proof.
SO VERY MANY OF THE MEMBERS HERE DON'T UNDERSTAND THE M/M ACT (commonly referred to as the "lemon law" or "warranty law" or other such stuff).
First and foremost, go directly to the source; go to the FTC website:
http://www.business.ftc.gov/documents/bus01-businesspersons-guide-federal-warranty-law
Read the ENTIRE thing, and all the sub-links.
Limited warranty coverage (which would apply to just about any brand of filter I know of offered in our market) is clearly defined in the company's written warranty statement. Check Puro, Fram, Champ, Wix, etc. You'll find them there buried in their stuff.
You see, when you follow the filter maker application chart, then IF there is a failure of the filter (performance or deterioration, etc) that results in engine damage, the burden of proof is upon the filter maker to show that their product did not cause the problem. This can turn into a war between vehicle OEM and filter maker, but you (the consumer) are not in this battle, other than being a time-riddled casuality.
However, if you DO NOT FOLLOW the OEM or filter maker recommendations, then it is YOU who MUST PROVE that your selection did not cause the problem. It becomes YOUR burden of proof to show that your oversized filter selection did not cause the issue. And I remind you that the OEM and filter makers have huges reams of data, hundreds of hours of testings, and a bevy of lawers to defend their position. What do you have? A hopeful list of BITOG members chattering about "flow" this and "byapss pressure" that. Even if you could ultimately win a session of legal intervention, it would only come after years of delays, wrangling, etc. You'd run out of time and money LONG before you were pronounced a "winnner" in this regard. I challenge you to show me case history based upon trial or arbitration that would conclude otherwise.
In regard to the OPs question, the greatest risk is that of outright warranty coverage denial or painful, significant delay so great that you'll wish you'd never gone off the reservation.
And for what? Using a filter that shows ZERO proof of being "better" (defined as reducing wear rates in a manner that can be shown to be statistically significant).
Admittedly, the risk of filter failure is very low to begin with, so the propensity for loss is extremely remote. But if that unwanted circumstance does arise, you are in for one heck of a long, uphill battle where YOU are the one who has to PROVE your choice was not the root cause. Good luck with that ...
And I will take the opportunity to remind you all that real data shows even normal filters in normal applications are grossly under-utilized to begin with. Using a "bigger" filter (falsely presumed to be "better" based upon size) shows no tangible gain over a typical recommended filter in the proper application. If you have proof (not heresay or conjecture, but real PROOF) then by all means, bring it forth for all to see.
