Originally Posted By: Clevy
Originally Posted By: Drew99GT
Let the superstitions begin!
NOT...... The usual place for oil leaks on the 3800s my family has owned are the oil pressure sender and the oil filter adapter gasket. I'd be checking those first things first.
Any oil dripping by where the filter mounts? That's usually the sign of the above 2 issues.
That would have to be barely a weep to lose a quart in 2500 miles. I doubt it would even become a drip.
So I'm taking bets here. I
think this thread is just another one of Merks boredom threads,and I doubt that there's any problems with the car,he's just fishing to see who will provide the common responses that always appear in these kinds of threads.
Such as consumption is common when first using a new oil and it may take an interval or 2 for stabilization to occur.
Maybe you need a high mileage oil(insert anecdote here)
Was there a lot of high speed driving on this interval?
What about the pcv?
Was the ground level?
Was the engine hot or cold. If hot then yes it's low,if cold then it's possible that the oil isn't low at all since oil expands when hot,and if you fill it to the top when cold it will be over full hot.
Did I miss any.
Hahaha
