Certain model year Mazda motors had a cartridge type filter. Mazda made a retrofit that allowed for typical spin on type oil filters to be used. There were questions about which oil filter to use and I was surprised at the number of different models members said you could use. For 35+ years of DIY oil changes, I always thought that oil filters were designed for specific engines. I thought the thread pattern of the oil tube could be different for different car manufactures, they operated at different oil pressures and such. Now i am thinking that basically if it fits without leaking and you are ok with the physical size, (like if you don't care if it sits lower than the oil pan) that you can use any filter.
I am not saying that I would not choose the recommended model for my cars, but if one day I grab the wrong filter for my car from my garage and installed it, and had no leaks, I wouldn't have caused major engine damage, or would I?
