Hello All,
The car in question is a family members 1992 Toyota Corolla. The issue is that there is a connection that I believe comes from the ignition switch to the starter, to tell the starter when to run, so this is leading to a intermittent hard start/no start.
It is a spade/blade style connector, I have tried bending the clamps on the spade end down to try and make it have a better connection, however this only worked for a short period of time.
My next plan of attack is to solder the blade end, to the spade end to force it to keep a good connection.. however the location of the connection is going to make this more than difficult..
I wanted to check with you guys and see if you had any recommendations for me? I know soldering it is not ideal but its the best I can come up with on short notice.
