Originally Posted By:
[email protected]
[email protected]
Haha Nick, I owned a 2002 Envoy for 8 years with that 4.2l I6. I even had it tuned by PCM4less to take out some of the torque mgmt and make it more fun to drive.
But that thing was a nickel and dimer. Every year I spent at least $1500 in maintenance. Most years more than that. Ive never owned a Jeep product and always thought the 2005- current day Jeep Grand Cherokee looked cool. Plus, Ive never owned a v8 powered vehicle either. I had to kill all birds with one stone, lol
the 4.2L I6 is no racecar, but is decent. Nothing beats a V8 though... I sure do miss my V8 Chevy truck. I often wonder if my grandma's Trailblazer is just a lucky one. The only repairs it has had are:
New water pump (wasn't leaking, but my mechanic buddy noticed it had a lot of play in it where the fan clutch bolted up)
1 single cylinder coil pack burned out. That was easy to replace.
Motor mounts vibrated
Mode door actuator for A/C went out. Wouldn't choose direction on A/C, only blew on defrost.
And now it has a power steering leak, not sure where though. Haven't gotten around to it.
Those are the only repairs it's ever had in almost 102k miles, unless you count brake pads. About $300-$350 in repairs.
Well, I keep an excel sheet on all of my toys. Heres a SMALL sample of went wrong with my Envoy in the FIRST year of ownership:
* Wiper motor (was recalled, but GM said mine was ok - 6 months later, it went bad and they wouldnt replace it)
* Front axle passenger side actuator, side bearing & housing
* Rear air load leveling suspension compressor (first time)
Second year:
* Front and rear sway bar end links
* Clutch Fan
* Drivers side memory control module caught on fire in the door. GM denies problem (ironic it was recalled a few years ago)
Third year:
* Idler tensioner pulley
* Rear parking brakes explode in drums. I had NEVER used them, nor do I offroad or tow.
* Air ride compressor #2
* 4 wheel drive switch stopped working, went bad.
* Liftgate stops working. Chafed wiring in liftgate from factory. Replace wiring harness $$$$
Fourth Year:
* Front wheel bearings (both sides)
* Drivers side front axle leak. Seal replaced.
* Nothing else "large" to report.
Fifth Year:
* Sway bar end links "again". Shocks all around.
* Air springs rotted and leaking.
* VVT actuating solenoid failed.
* Water pump leaking and wobbly, replaced.
* #4 coil fails from water leaking from the hood. Replaced.
* Transmission lines rot, had to use GM OEM parts $$$$$$
* Thermostat & Alternator failed this year too, few months apart from each other
Sixth Year:
* Air ride compressor "AGAIN". This time, since they fail so often, I buy a used one on ebay for $100. It ended up being the best one, go figure.
* Rear axle seals leaking. Replaced
* Air conditioning pressure switch replaced.
* Heater core lines leaking at firewall. Replaced (Dealer only part) $$$
Seventh Year:
* Driving and hear POP BANG. The studs that hold on the rear sway bar rotted, broke and fell off. Had to drill out what was remaining of the old studs and put on a bolt & nut.
* VVT Actuator INSIDE engine fails. Replaced, along with valve cover & intake gaskets $$
* Water pump (again).
Eight year:
My last and final straw, the power steering lines rot and are leaking on the strut tower. I sell that TURD on craigslist and bought a Toyota, which I still have & love. Total cost of Toyota maintenance besides oil changes in 94,000 miles= $0.00 lol
I am leaving out TONS of small minutia like the headlamp sockets that constantly burn and melt, I finally soldered in ceramic plugs that still burned, but kept working. I had to replace the brake light "modules". There was a recall for this too, they replaced mine and they STILL went bad. I ended up replacing the front drivers side axle seal once more, for a total of two times. Was weeping again when I sold it. I used Amsoil in the front and rear axles btw. My transfer case encoder motor went bad, I just remembered that. OH, and it ate through ignition switches like every 2.5 years.
THANK God I did 99.99% of the work myself, or I'd have been bankrupt in a major way paying the dealer or mechanic!!
Oh.... my ..... God
I haven't done that many repairs on all my vehicles I've ever owned put together!!
And I've put about 600,000Km on them in total. The Expie is headed to hit 300,000 in the next year and it has had tires, brakes, a few coils, one popped plug, one set of end links, two batteries, one alternator and shocks. That is absolutely mind blowing that you went through that!
No kidding.
I've put together entire cars that needed less work than that.
Had that been me I'd never buy another GM ever again. That's horrible.
And the wiper motor burn would have really dug at me.
I've had nothing but good experiences with gm products,however I've only ever owned v-8 specimens,and my trucks didn't have any push button or knob actuated 4wd. Always a lever,til my c3 which is awd.
Overkill. That tank you own will last you a lifetime. Never sell it.
I've seen 5.4L 2v engines with 500000kms on them. Work trucks,pulling trailers. One was a stucco guys. Always overloaded trailer,sporadic maintenance at best yet mechanically nary a serious issue. Even the tranny was still decent.
The expedition may not be a daily driver but it'll last,especially if you just use it when required. For example camping pulling a trailer or winter useage when inclement weather hits.
The trailblazers inline 6 was supposed to become legendary for durability. What happened?
It it neglect or why am I seeing a lot of negative experiences with them.
Or is it internet amplification?
Sorry for the off topic post.
