Originally Posted By: Jonlee89
Ok so the stock Subaru oil was breaking down faster due to the heat of the turbo so I searched for oils that might withstand the heat a bit better I previously used royal purple in my other cars and had used some of their other products and they were great but I was still having the oil break down and leaving internals fairly dirty now I change my oil normaly ever 1,600-1,800 miles then I had been thinking about trying the eneos oil for a while and they remove some things from thier oil and replace it with other properties for their blend pack and it's designed to help keep the oil and engine cleaner and I drove on that and not only was it still clean and almost looking still brand new my engine ran smoother at idle then other oils and while driving the same roads useing cruse control keeping the car at as close to the same speed and rpm as possible there was gas mileage improvement regaurdless what others think on the stock Subaru oil my mpg was a low of 15.6 driving some what aggressively and a max mpg of 25 badly touching the gas every were I went not to impressive and I was surprised to see the change I. Mpg but it did in fact.
Okay, couple of things. First of all, does your ISP charge you extra for using punctuation? Like is there a money saving thing going on with the absolute lack punctuation?
The reason I ask is because if I was to ask a question that I wanted people to help me with, I would want to express it in a way that's easy for them to understand so that I could get a helpful/correct answer from them. However, I feel your writing style of no punctuation, and comments flowing into one another without transition, makes it difficult to understand.
As for your comments, how do you know the stock Subaru oil was breaking down? How do you know that Royal Purple was breaking down and leaving the internals dirty?
Changing your oil every 1,600-1,800 miles is overkill. It doesn't protect your oil any better, it wastes your time, and it wastes your money. Even Subaru doesn't suggest changing your oil under 3,750, so you can safely double your OCI.
Using a quality Xw-30 or Xw-40 oil will protect your engine and turbo, and ensure you don't have an oil related issue for a long time; (gasket leaks are not a motor oil issue, they're a known occurrence on Subarus).
