I'm not sure I've ever seen a Trader Joe's that wasn't insanely busy. It seems like the trick is to show up early in the day, at least here.
Back on topic... researching other cars that people recommend as good alternatives if buying new I've found that if you go used, the Prius seems to be a much better bargain. An example is that I found a '10 Prius III with 65k miles on it for $14,500. Next I searched for Honda Civic with no more than 75,000 miles and less than $15,000. On the high end, there are Civics that cost the same as that Prius with the same miles, but on the low end you save maybe a couple thousand dollars and get a car with half the miles.
But are those ~30k miles all that big of a deal with a car that's as reliable as the Prius seems to be? Here's the numbers...
300 miles a week @ $3.40 a gallon measured at listed combined rating (sanity checked on Fuelly to determine reasonable accuracy)
Prius @ 50 MPG costs $1176.66 / year
Civic @ 29 MPG costs $1828.97 / year
Prius saves you $652.31
So lets say you buy the Civic in similar condition for $2000 less, which is a reasonable estimate... if you plan on keeping this vehicle for longer than three years the Prius wins. There are many solid alternatives to the Civic, like the Cruze Eco, but the equation seems to work out to roughly the same numbers in the end.
