Originally Posted By: Rolomoto
I can't get the castle nut off the lower ball joint. When I try and turn it, the whole wheel turns.
If the whole wheel and knuckle is turning as you say it is, take the key out of the ignition so the steering wheel locks. Then use a BOX end wrench or two doubled up for leverage.
The gear ratio in the steering rack will limit the pressure on the wheel lock and not be a problem. Dont resort to fire and chisels until you have immobilized the steering.
