Originally Posted By: landtoy80
Son just bought a 2004 Rav4 and there is a mix of Toyota Pink/Red and Green coolant. I know they are not compatible and cause problems. Is there a flush solution that will clean up what ever buildup the mix made?
I have filled with water right now.
Are you sure you have buildup? Just because incompatible coolants were mixed, doesn't automatically mean there is buildup. I would fully flush the system with distilled water to the point where it’s almost 100% water and drive for a bit to make sure everything works including heat. After that, drain the radiator and take a look at the drained water. If it’s no longer clear and has some weird color to it, move on to a chemical flush. Or if the water comes out clear, just put the proper amount of concentrate.
I would be hesitant to use a chemical flush without knowing first if it's even needed on an older system. You never know how it will react with aged materials and can introduce leaks.
