Inner Tie-rod removal
by Sawdusted
02/06/16 09:54 PM
What's a good price for a 2013 4Runner?
by Gebo
02/06/16 09:34 PM
Chrysler 42LE - avoid synthetic gear lubes
by Wampahoofus
02/06/16 09:15 PM
Nose mask (car bra) tab repair
by aquariuscsm
02/06/16 08:53 PM
Eye Watering HeadCold ! Help!
by SumpChump
02/06/16 08:43 PM
Dean tires?
by Corollaman
02/06/16 08:32 PM
Discount Tire Direct Presidents Day Sale
by sopususer
02/06/16 08:21 PM
New CarQuest R85372-A43301 cut open
by WellOiled
02/06/16 08:11 PM
Pennzoil Ultra old SN formula.....
by mv6845
02/06/16 08:07 PM
80 Hypoid?
by ledslinger
02/06/16 07:46 PM
Whatever happened to Meyer's invention?
by OneEyeJack
02/06/16 07:07 PM
window tinting
by crestwood
02/06/16 07:05 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
83 registered (01_celica_gt, 77GrandPrix, 2015_PSD, 69GTX, 5 invisible), 1276 Guests and 192 Spiders online.
56834 Members
66 Forums
244338 Topics
Page 2 of 2 < 1 2
#3391725 - 06/07/14 07:49 PM Re: How well does your engine handle low oil levels? [Re: RPMster]
andyd Offline
Loc: Marshfield , MA
The Wag's oil pressure gauge would read lower than normal and that was the clue. My Bmws have a low oil level warning light.And low coolant too. The current pair sling off a pint pretty fast, then settle down. The Rat doesn't use much oil either.
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3391729 - 06/07/14 07:54 PM Re: How well does your engine handle low oil levels? [Re: RPMster]
WeenieHutJr Offline
Loc: Washington
I did an oil change on a 2011 Forester with the FB engine and 1.5 quarts came out. I think last oil change was 12k miles and 4-5 months ago.
#3391791 - 06/07/14 09:59 PM Re: How well does your engine handle low oil levels? [Re: RPMster]
Chris142 Offline
Loc: apple valley, ca
My jeep does not use oil between changes so its always full. 6Qt sump so 5 qts is still in it @add.my ford does use some oil.11qt sump.9 left when at the add mark.ill throw in a qt or 2 then. But it does not effect how it runs.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3391809 - 06/07/14 10:28 PM Re: How well does your engine handle low oil levels? [Re: RPMster]
Clevy Offline
Loc: Saskatoon canada
What's a low oil level?
My oil levels in everything i own is either full,or empty because I'm changing it.
2006 Charger RT
Miles x 2 per oil filter
#3391823 - 06/07/14 10:52 PM Re: How well does your engine handle low oil levels? [Re: RPMster]
01rangerxl Offline
Loc: Birmingham, AL
Nothing I have owned or driven regularly has truly been low on oil. Low on oil for my truck is half way down the safe range on the dipstick. At that point it's usually due for an oil change anyway.
The cars I have seen that were more than a quart low on oil ranged from "running fine" to knocking/valve clatter. Sometimes it went away with a change, sometimes not.
This question varies depending on your definition of low and how long it has been there.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 180K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 176K miles
#3391826 - 06/07/14 10:53 PM Re: How well does your engine handle low oil levels? [Re: RPMster]
147_Grain Offline
Loc: USA
"How well does your engine handle low oil levels?"
Don't know, as my oil levels are always 1/16" to 1/8" over the full mark.
Perhaps you can intentionally run a few of your vehicles low on oil and educate us on this conundrum. wink
#3391887 - 06/08/14 12:23 AM Re: How well does your engine handle low oil levels? [Re: Turk]
bvance554 Offline
Loc: VA
Originally Posted By: Turk
I can hear it in the engine when both the 2000 & 1998 Saturn SL2's are 1/2 quarts low.
That is amazing. Because I've ran Saturns with no oil touching the dipstick and you would never know the difference. You must have a very keen sense of hearing.
How much oil is actually in circulation in an engine? Probably less than a quart. I bet every vehicle would run just fine with no damage on a quart of oil. The sump is a resevoir...
#3391946 - 06/08/14 05:44 AM Re: How well does your engine handle low oil levels? [Re: widman]
Rick in PA Offline
Loc: Southeastern, PA
Originally Posted By: widman
Some cars will drink a lot until the half way mark, then none...
Interesting point. With several others raising the same issue, it got me to thinking. Is it likely that when the oil pan is tippy-top full, the windage from the crank makes more of an aerosol of the oil, which is then drawn off through the PCV system?
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
#3391965 - 06/08/14 07:25 AM Re: How well does your engine handle low oil levels? [Re: Rick in PA]
fdcg27 Offline
Loc: OH
Or maybe enough oil gets splashed onto the cylinder walls that it overwhelms the rings' ability to wipe it off?
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 152K Defy 10W-40
#3391977 - 06/08/14 07:45 AM Re: How well does your engine handle low oil levels? [Re: RPMster]
supton Offline
Loc: NH
Haven't ever ran one to lower than "add a quart", which is when I add a quart. But the current fleet does not use oil over there 10k OCI so I have had not had this issue for a long time.
On my Saturn I timed it so that it would be needing an oil change when it got a quart low. Ran just fine.
2011 Toyota Camry, base, 6spd manual, 107k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 114k, his
#3391997 - 06/08/14 08:24 AM Re: How well does your engine handle low oil levels? [Re: bvance554]
Turk Offline
Loc: MN
Yea, I pay very close attention.
To be more specific, the engine starts sounding a little "raw".
I check it & sure enough, 1/2 quart low. smile
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#3392168 - 06/08/14 12:37 PM Re: How well does your engine handle low oil levels? [Re: Turk]
Powerglide Offline
Loc: SE Florida
Saturns of that vintage will take an enormous amount of abuse.
Page 2 of 2 < 1 2
