I am having a bit of a time trying to diagnose the idle issue on my jeep.
If I start the jeep with a single prime of the fuel pump, it will start and have a high idle that won't drop, and then after it reaches operating temperature the idle will romp up and down between 1100 and 300rpm.
If I prime the fuel pump several times it will start and run fine. I have checked fuel pressure and it is stable at 50psi no matter the scenario.
NOW RECENTLY it will start and die. I have a CEL for P0505 which is IACV, but the the IACV is new and I have tried another from my Dodge Dakota. The truck will only stay running if I hold the throttle down halfway and it will sputter and pop as if it is running lean.
