1997 Saturn P0326 No power
by nwjones18
08/29/16 04:29 PM
Can I use lower weight ?
by ST2008
08/29/16 04:25 PM
Amsoil 0W-30 Honda S2000 40,259 OCI w/bypass
by slalom44
08/29/16 03:32 PM
Holdup
by Whitewolf
08/29/16 03:14 PM
boosting diesel perf using propane/CNG/meth added
by columnshift
08/29/16 03:04 PM
HP for '96 Toyota Corolla?
by Benzadmiral
08/29/16 03:04 PM
Gene Wilder Dies at 83
by John_Conrad
08/29/16 02:52 PM
Simple oil question, Honda GCV 160
by Popsy
08/29/16 02:49 PM
BMWs Remote 3D View
by HTSS_TR
08/29/16 02:25 PM
I changed my p.s. fluid, it's easy (with pics)
by TmanP
08/29/16 02:20 PM
Abandoning the Fumoto Valve Plan
by CrackyWainwright
08/29/16 02:18 PM
New Shed/Garage, A Couple Questions
by Bob5150
08/29/16 01:08 PM
LazLong, gioburk, turrican, GGilbert, leje0306
58952 Registered Users
98 registered (2oldtommy, Al, 2015_PSD, 09_GXP, 8 invisible), 1743 Guests and 11 Spiders online.
58952 Members
66 Forums
253735 Topics
Page 8 of 9 < 1 2 3 4 5 6 7 8 9 >
#3198822 - 11/26/13 03:05 PM Re: CHECK YOUR TIRE PRESSURE! [Re: JHZR2]
coopns Offline
Loc: Scituate MA
Way home today I said to myself, haven't check the tires in a year. Lo and behold, one was a 12, others were all low. Wondering why gas milage was a bit low.
Coop
#3224154 - 12/21/13 10:13 PM Re: CHECK YOUR TIRE PRESSURE! [Re: KimikoYuuki]
Subdued Offline
Loc: Youngstown, NY
I run 35 PSI of 80% nitrogen, 16% Oxygen, and 4% a mix of other stuff in my Yaris.
Seems to hold up pretty well.
2008 Chrysler Town & Country Touring 119k
2007 Toyota Yaris S 135k
2001 Toyota Corolla LE 159k
2001 Toyota Corolla CE 128k
#3226205 - 12/24/13 06:58 AM Re: CHECK YOUR TIRE PRESSURE! [Re: Subdued]
JetStar Offline
Loc: Flatlands of Indiana
I find it amazing how may people that I know, don't check their tire pressure regularly, including motorcycles. I guess that's how we end up with TPMS. What floors me is that my Son is one of them, and he certainly was NOT taught that way.
BTW I noticed the tires on my Tacoma are wearing a bit in the center when I rotated them this weekend, factory Dunlops with 30 PSI on the placard and 30K on the tires. I think I'll drop the pressure a bit.
My weakness is I love all motorcycles regardless of brand
2016 Suzuki DR650
2015 Road Glide
2007 Yamaha FZ1
1978 Suzuki GS1000 (now 1085)
#3243028 - 01/09/14 04:09 PM Re: CHECK YOUR TIRE PRESSURE! [Re: JHZR2]
Benzadmiral Offline
Loc: Da Swamp
Ever since I got a plug-in tire pump as a gift, I make sure to check my tires every month or so, and before a trip. On the Park Avenue, which called for 32 all around, I usually aimed for a compromise between ride quality and better economy, and ran 33-34 most of the time, 35 if I knew I'd be on a sustained highway run. The '11 Regal calls for 33 all around. One menu has an LCD display of the pressure at each tire. So far they've been reading 37-38 -- but that's after a half-hour drive or more.
I'll check it this afternoon before I leave work, when the tires have been sitting, and then compare that to what I actually read with the pencil gauge on Saturday morning.
-- Paul W. (The Benzadmiral)
('11 Buick Regal CXL, charcoal/cream, 2.4L NA)
http://benzadmiral-uncle.blogspot.com/
#3258233 - 01/24/14 05:31 AM Re: CHECK YOUR TIRE PRESSURE! [Re: JHZR2]
KitaCam Offline
Loc: SunnySouthFlorida
Since getting 17" rims and performance tires, Hankook Ventus V4 ES, I've been running 40psi and a bit more as I figure out the best settings for the Camry, a jump from 35 I had been running in 15 inch "OEM" type tires...this vs. 29 on the doorjamb...
As high as this is, it seems to be the right settings for greater traction/wear/and mpg. With cold temps this month in Florida following last month, Dec., the hottest on record here, I've had to keep an eye on them...
Edited by KitaCam (01/24/14 05:34 AM)
Kitacam is an 05 Camry LE/I4/MT; 3/16 @ 137,000....MaxLife Syn Blend 5w-30...with P1 filter
#3347520 - 04/19/14 04:43 PM Re: CHECK YOUR TIRE PRESSURE! [Re: JHZR2]
Benzadmiral Offline
Loc: Da Swamp
For those of you who even have a compact spare:
Check the pressure in it. The Buick dealer's pre-printed 172-point checklist sheet mentions the other tires, but not the spare. Just now I unpacked the trunk, levered up the floor panel, and gauge-checked my spare. It was 18.5 psi, and it's supposed to be 60! My Sears inflator was getting a little hot by the time I finished pumping 48 pounds into the tire.
'Twould be embarrassing, to say the least, if I got a flat on the road somewhere, unshipped the spare, and found it dead flabby, no? (Yes, I have a can of the Fix-a-Flat stuff . . . but I've never used it. Ounce, prevention, cure, you know the drill.)
I will give Buick/Opel full credit: The spare is stowed with the valve uppermost, so you don't have to take the tire out and flip it over to check the pressure. I had to do that every year on the Park Avenue; annoying, to say the least. . . .
#3348679 - 04/20/14 10:53 PM Re: CHECK YOUR TIRE PRESSURE! [Re: JHZR2]
GoStumpy Offline
Loc: BC, Canada
I'm running 35psi vs the 29 recommended in the doorjamb... I think they recommend 29 just for the cushy ride...
2006 VW Jetta Wagon TDI
2002 Nissan XTerra S/C
#3356396 - 04/29/14 04:46 AM Re: CHECK YOUR TIRE PRESSURE! [Re: JHZR2]
pitts64 Offline
Loc: Pittsburgh, Pa
My 64 Bonneville likes 39.. The tires are West Lake SU307 235/70r15... I removed all rubber bushings from the control arms, spherical in the back, Delrin/Nylon in the front...
The roads in Western Pennsylvania are like a demanding road course..
Edited by pitts64 (04/29/14 04:48 AM)
#3409971 - 06/29/14 12:08 PM Re: CHECK YOUR TIRE PRESSURE! [Re: Prelude]
geeman789 Offline
Loc: Western Canada
Originally Posted By: Prelude
I find it excessive to check the pressure once a month unless there is a problem. The pressure in my tires doesn't change much even after 3 month...
How do you know there is in fact a problem if you never check....!?!?
I check pressure once a week, every weekend. I also check oil, coolant, ps levels, and top up washer fluid.
My tire pressure checks have a number of times gone like this...
35 35 35 35 21.... what the ...!
Picked up a screw... leaking a couple psi per day, no big deal... and no flat on the side of the freeway...or worse!
It takes all of about 2 MINUTES to check four tires ... excessive, umm, no...
Good preventative maintenance is how I prefer to look at it.
2011 SUBARU Impreza 5 spd manual / 2007 HONDA Odyssey
#3415851 - 07/06/14 06:31 AM Re: CHECK YOUR TIRE PRESSURE! [Re: JHZR2]
sprintman Offline
Loc: Canberra ACT Australia
40-42 psi bottled nitrogen. It varies very little when I drop in for a check.
#3415890 - 07/06/14 07:55 AM Re: CHECK YOUR TIRE PRESSURE! [Re: JHZR2]
SteveSRT8 Offline
Loc: Sunny Florida
^^^That figures.
Why don't you just tell us all about "Nitro" and it's innate superiority...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3415891 - 07/06/14 07:56 AM Re: CHECK YOUR TIRE PRESSURE! [Re: pitts64]
SteveSRT8 Offline
Loc: Sunny Florida
NICE! I had a gorgeous 63, one of my best memories....
#3480778 - 09/12/14 08:57 AM Re: CHECK YOUR TIRE PRESSURE! [Re: JHZR2]
ZachMcgowan Offline
Loc: El Paso, TX
This is the reason why I decided to buy a Digital Tire Gauge from Mountaincrest a month ago because of some big fluctuations in my TPMS. Just making sure everything is working out well while I'm driving off to some great distances.
#3480845 - 09/12/14 10:03 AM Re: CHECK YOUR TIRE PRESSURE! [Re: ZachMcgowan]
leeharvey418 Offline
Loc: Southeast Michigan
Wow, Zach... you sure do like your Mountaincrest Digital Tire Gauge.
2010 Mazda3 s Grand Touring
2014 Mazda CX-9 Touring AWD
#3500939 - 10/03/14 11:00 AM Re: CHECK YOUR TIRE PRESSURE! [Re: JHZR2]
ThirdeYe Offline
Loc: Walker, MI
I just wanted to add a little something to this thread... don't forget to check your spare tire pressure as well! I was changing the passenger side tail lamp last night in the Firebird and I had to remove the spare tire to get to it. It looked fine, but as I was rolling it in the garage and put some pressure on it, I noticed it was getting very soft. I checked the pressure and it wasn't even registering on my gauge. Had I not changed the tail lamp, I would probably not have noticed how low it was until disaster struck.
99 Pontiac Firebird - 93k - Havoline 10W-30/Purolator PureOne PL10111
08 Scion tC - 122k - Pennzoil Platinum 5W-20/Fram XG4967
