We know that GTL bases come in 3 grades: 3, 4 and 8. Synthetic grade numbers are typically based of the kv100 meaning these grades will be close to 3 cSt, 4 cSt and 8 cSt.
Using a blend of these 3 grades will be what delivers the final viscosity, the 10W30 will have the most of the 8 cSt grade (probably around 60%), none of the 3 cSt and probably half the amount of viscosity modifiers vs 5W30. Because NOACK is influenced by the viscosity of the base oil (thinner oils evaporate more easily) it easily explains why 10W30 would be much lower.
There are other ways to achieve low NOACK for the finished product, but 10.3 is still solid performance considering the current max for SN is 15 and the proposed GF-6 Spec is 13.
Of course my formula numbers are just estimates based on other synthetic engine oil blends.
