Originally Posted By: pbm
Is this still true if the car doesn't burn (use) oil?
Yes it's true because every car consumes oil, obviously the effects would be different between a car that consumes a quart in 5,000 miles and one that consumes the same quart in 50,000 miles.
But even in an engine with moderate consumption and using oils high on additives, the catalytic converter doesn't die immediately, and maybe you won't need to replace it in the car's lifetime, but the efficiency will decrease, and the car, for example, instead of emitting 10 ppm of NOx, it will emit 50 ppm, which is still a good number, but if you multiply it for 4 million cars in a city, that is a lot of smog that could be prevented.
So, maybe you don't care about the environment, (I know I don't care, specially if people are having children like bunnies) but as I said in my last post, an oil with newer technology, will protect the engine equally well even if it has fewer additives.
