Originally Posted By: subaroo
and yet I've never used sta-bil or any other and my ope fires up 1st time every spring as well. so who knows, I doubt it hurts anything to use the stuff. I also thing it depends on how good your fuel source is to begin with.
we have 3 refineries nearby, all within 100mile radius.
Fuel is as fresh as it can be the unless you go with 94 octane rating, otherwise: all E10 varieties.
Been on E10 for over 2+decades now...all of our automobiles, OPE engines are on E10 as far as my memory can recall.
Not a whole lot of E10 related issues on OPE engines but then again: still have those occasional "blame them all on E10" excuses and stigma on OPE folks (or folks who have been a stinkker RE: their junk car basic maintenance, carb needs rebuild, tuneup off and everything else in between).
Also: had lots of bad rap with the only 2 local OPE engine shops in town: they charged an exorbitant price on servicing OPE mower engine issues, but never fix them right...and when you go back to complain, they all blame the E10 part...guess what? quite a few of these so-called engine issues are easily fixed (most of them just require a quick side draft carb bowl drain-n-fill, with compressed air clearing the orifices), others are mostly flywheel key sheared or almost sheared (shifted as I called it), leading to hardstarts, rope kickbacks, etc.
Of course, I have been a strong advocate RE: using fuel stabiliser in all OPE engines here in our neighbourhood, amongst other things such as adding a red (150micron) mesh filter to those side-draft carbs, use HDEO in air-cooled B&S and Honda OPE engines, etc. Never an issue with carb gumming as far as I can recall (except those that left their mowers out to the element during winter times, usually mower ended up so rusty that it's literally toasted...bought a new one and in a couple of years time, same deal due to owner's intentional neglect.
My 2c's worth.
Q.
