Tacoma Extended OCI
by 13Tacoma
06/29/16 01:07 PM
Gear oil mixed in with Diesel Engine Oil ...
by Miller88
06/29/16 12:07 PM
DELO ELC Antifreeze/Coolant??
by Griz95
06/29/16 12:06 PM
Higher oil pressure. Oil? Filter? Jeep 4.0
by RegDunlop
06/29/16 11:16 AM
NJ's gas tax increase
by Whimsey
06/29/16 11:11 AM
PAO in Mobil 1 0w-40
by loneryder
06/29/16 10:33 AM
2010 Porsche Boxster S, Mobil 1 5w50, 4,700 miles
by Croc
06/29/16 10:18 AM
Amsoil announces 6% price hike
by Kuato
06/29/16 09:28 AM
737 NG
by SEMI_287
06/29/16 09:10 AM
ACDelco vs Valvoline oil filter
by mbar1
06/29/16 08:21 AM
Valvoline Premium Blue RestoreTM
by Rat407
06/29/16 08:16 AM
Dealer says 07 Highlander has strainer. Nope!
by CapitalTruck
06/29/16 08:04 AM
dpaldino, T_Bortz, rebelx, dougsangster, CrazyCalvinW
58314 Registered Users
94 registered (aquariuscsm, alphadog, 13Tacoma, Astro14, another Todd, 8 invisible), 1948 Guests and 11 Spiders online.
58314 Members
66 Forums
250982 Topics
Page 3 of 4 < 1 2 3 4 >
#3329766 - 03/31/14 09:58 PM Re: Help! The wrong oil was used! [Re: turtlevette]
dave1251 Offline
Loc: Maricopa, AZ
Common sense.
Keep in mind I am one that prefers thin as possible.
Too thin you have a dead engine. Too thick the engine is just a little less efficient.
don't use.
#3329815 - 03/31/14 10:47 PM Re: Help! The wrong oil was used! [Re: Mantachieman]
Merkava_4 Offline
Loc: Clovis, CA
Holy wall of text Batman!! shocked2
#3329877 - 04/01/14 12:57 AM Re: Help! The wrong oil was used! [Re: dave1251]
turtlevette Offline
Loc: Massachusetts
Originally Posted By: dave1251
Common sense.
There is a study somewhere here on the site that does a statistical analysis on all the UOAs here. The 20wt oils show lower iron as a pattern than the 30wt.
I'll try and find it again.
#3329890 - 04/01/14 01:54 AM Re: Help! The wrong oil was used! [Re: turtlevette]
turtlevette Offline
Loc: Massachusetts
#3330128 - 04/01/14 09:21 AM Re: Help! The wrong oil was used! [Re: Mantachieman]
Dallas69 Offline
Loc: Texas
Leave it in
It wont hurt at all
I am starting to think that BITOG does more harm than good cause folks start over thinking
2009 Galant-ultra oil and filter
1987 Ford F-150 302
Valvoline Maxlife 5-30
Motorcraft filter
#3330143 - 04/01/14 09:42 AM Re: Help! The wrong oil was used! [Re: Mantachieman]
thomasew Offline
Loc: North Carolina, USA
Don't feel bad, one time I took my truck to the dealership for some stuff, and an oil change. I had the oil and filter in a box in the open bed of the truck, and I told them to use the oil I provided. When I went back to get it, the oil that I bought, and the filter were still in the box in my truck bed. I thought about asking them why, etc., but decided to just forget it, and go on. I am pretty sure I had mobil 1 and a wix in the box, but that is not what went on and in the truck. I figured it isn't worth getting into it with them, so, I didn't.
#3330154 - 04/01/14 09:49 AM Re: Help! The wrong oil was used! [Re: turtlevette]
dave1251 Offline
Loc: Maricopa, AZ
Originally Posted By: turtlevette
You realize trying to use UOA's on a micro level to establish wear trends are widely inaccurate. Correct?
don't use.
#3330328 - 04/01/14 01:05 PM Re: Help! The wrong oil was used! [Re: Mantachieman]
Black_Thunder Offline
Loc: Wisconsin
i know companies that ran bulk oil in everything, including company cars spec'ed for 5w20.
bulk oil was 5w40 to 15w40, then it was 10w30 hdeo for awhile, now its 10w40
I'd buy Callahan autoparts if I could.
#3333743 - 04/04/14 10:56 PM Re: Help! The wrong oil was used! [Re: Mantachieman]
TiredTrucker Offline
Loc: Central Iowa
While the general consensus is that the 20w oils were introduced because of CAFE standards, I have read some stuff recently that the main motivation for the 20w oils over 30w oils was that the 20w will dissipate heat more quickly. Not sure if that was the reason, but a lighter fluid will generally dissipate heat quicker.
In order to know what is bad, you have to know what is good. The question them becomes, what is the source of knowing what is good?
#3333790 - 04/05/14 01:03 AM Re: Help! The wrong oil was used! [Re: TiredTrucker]
Shannow Offline
Loc: Oz
that's a claim that demands some evidence...got some ?
#3333800 - 04/05/14 01:29 AM Re: Help! The wrong oil was used! [Re: Shannow]
turtlevette Offline
Loc: Massachusetts
The thinner oil flows from the rod bearings faster providing more cooling oil to the piston. You know, like in power plants more flow transfers more heat. Get out your thermo book.
#3333801 - 04/05/14 01:43 AM Re: Help! The wrong oil was used! [Re: turtlevette]
Shannow Offline
Loc: Oz
With a positive displacement pump that shifts the same volume of oil for each and every revolution ?
#3333805 - 04/05/14 02:09 AM Re: Help! The wrong oil was used! [Re: Shannow]
turtlevette Offline
Loc: Massachusetts
The oil pump bypasses oil at anything above fast idle.
#3333812 - 04/05/14 02:18 AM Re: Help! The wrong oil was used! [Re: turtlevette]
Clevy Offline
Loc: Saskatoon canada
What?
First off an oil pump doesn't bypass anything. Some new engine have an oil pump that is variable,meaning basically it's able to adjust volume depending on engine needs however I'm not aware of any pump that is able to bypass anything.
Either the engine has a bypass built in to the oil circuit and when pressure exceeds a specific psi it will bleed off the excess pressure back into the pan,or the oil filter is equipped with the bypass valve.
So again. You're incorrect.
This isn't even fun anymore. Pointing out the flaws in your posts is getting old. It's such a common event lately that it's become stale.
Thanks for trying though.
All a steer can do is try....eh
2006 Charger RT
Miles x 2 per oil filter
#3333865 - 04/05/14 06:53 AM Re: Help! The wrong oil was used! [Re: Mantachieman]
demarpaint Offline
Loc: NY
Another vote for leaving it in.
God Bless Our Troops
