More destruction ahead?
by andrewg
05/01/16 10:17 AM
Sticky intake valves
by Ozzmosis
05/01/16 10:11 AM
2003 Ford Explorer Sport XLT Differential Fluid
by TalNum
05/01/16 10:03 AM
QSUD in Ecotec: 2 qts. consumed in 3K !
by Benzadmiral
05/01/16 09:54 AM
Utica or SK Torque Wrench?
by ET16
05/01/16 09:50 AM
Fly me to the Moon...
by reemoe2
05/01/16 09:45 AM
Old HONDA almost too good to be true in Wisconsin
by SumpChump
05/01/16 08:56 AM
VW and Shell accused of trying to block EV push
by wemay
05/01/16 08:30 AM
(previously repaired) cracked 351 block. trash?
by tomcat27
05/01/16 08:12 AM
CarQuest #84045, 600 miles CUT OPEN
by car51
05/01/16 08:10 AM
Molybdenum, is there a downside?
by 5170
05/01/16 07:52 AM
Cleaning 'Foggy' Headlights
by coopns
05/01/16 07:45 AM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
94 registered (901Memphis, AirgunSavant, 2015_PSD, 86cutlass307, Alex38, 13 invisible), 1853 Guests and 302 Spiders online.
57758 Members
66 Forums
248293 Topics
Page 1 of 2 1 2 >
#3253011 - 01/19/14 12:12 PM 2001 golf reliability
spasm3 Online   content
Loc: out there
I am thinking about a 2001 golf with only 40k on it at a dealership. Its a stripped down model with a manual trans.I have no experience with vws. I figure it has a timing belt. were these decent cars? Any input from any owners here would be appreciated.
13 elantra 42k 5w30 ultra
03 chevy avalanche65k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 74k 5w30mc5k
#3253036 - 01/19/14 12:42 PM Re: 2001 golf reliability [Re: spasm3]
renegade_987 Offline
Loc: Ankeny, IA
At only 40K the timing belt/water pump is probably original, so I would have that changed ASAP (which can be a $1000+ job at a dealer) As far as reliability, I cant comment on the Golf but a friend at work has a 2003 Passat that he has sunk $8K in within the last year, and its mostly hit or miss from what I've heard
2004 F150 186K Valvoline WB/Motorcraft FL-820S
2005 Ford 500 Limited 128K Motorcraft/Motorcraft
2011 Baja MB200 Royal Purple 10w30
#3253039 - 01/19/14 12:45 PM Re: 2001 golf reliability [Re: spasm3]
antiqueshell Offline
Loc: chicago, Illinois
Actually that is a very nice car, the only problems they had were weak coil packs and power windows. I am assuming that when you say stripped it has manual windows cranks?
The coil issue was addressed by a recall so as long as the car appears to be running well there should be no problem. Ask the dealer to find out whether the original coil packs were replaced under the original recall by VW.
No reason whatsoever to have the water pump changed at only 40k they commonly go for over 100k.
Otherwise the MK4 Golf made in Germany, was a very nice car.
Edited by antiqueshell (01/19/14 12:46 PM)
#3253044 - 01/19/14 12:48 PM Re: 2001 golf reliability [Re: antiqueshell]
Loc: Ankeny, IA
When I said that they should be changed I was going by age, not miles.
#3253061 - 01/19/14 01:05 PM Re: 2001 golf reliability [Re: renegade_987]
Still no reason. I have a 20 year old MKIII Golf that has 125k on it and no signs of leaks as of yet from the water pump. The design is very similar on both.
#3253094 - 01/19/14 01:47 PM Re: 2001 golf reliability [Re: spasm3]
gregk24 Offline
Loc: FL, USA
VW are hit or miss as far as reliability goes.
2012 Honda Accord EX-L
Taffeta White - Ivory
38,xxx miles
PPPP 0w20 / Fram Ultra
#3253114 - 01/19/14 02:00 PM Re: 2001 golf reliability [Re: spasm3]
bigjl Offline
Loc: London, England
Not worth the risk with a VAG water pump by trying to "save" a few quid.
Around that time VAG had issues with water pumo impellers sheering internally causing overheating.
At that time the Golf was fairly robust if a bit of a pudding compared to earlier variants.
Would make a decent enough car for long term use.
Usual siezing rear calipers will need attention. Especially in a low miler.
I wouldn't pay a premium for the low miles as i have never found an old low miler to be more reliable than a well serviced high miler. Often the opposite due to degradation of rubber components.
Do dealers in the US really try to charge $1000 for a cambelt on simple engines like these?
Polybushing the suspension will be a worthwhile investment though.
If you like it go for it.
And make a complete cambelt job part of the deal. Tensioner, idlers and water pump. With sight of the old parts to make sure.
The water pumps in modern VAGs really are a lottery.
14 Kia Picanto 1.0 City 10k miles. Kia 5w30
07 Citroen Berlingo Multispace 1.4i 39k 10w40 Maxlife
#3253119 - 01/19/14 02:03 PM Re: 2001 golf reliability [Re: antiqueshell]
bigjl Offline
The water pump in the mk3 never had the same reputation as the one in later Golfs.
Water puml failure with new tensioner and belt is too big a risk for me to take in the pursuit of saving under 40.
#3253147 - 01/19/14 02:19 PM Re: 2001 golf reliability [Re: spasm3]
Loc: out there
So its not a real problem car then. Its listed at $5900. I was thinking more like $4000.It is manual windows, that part i like!
Edited by spasm3 (01/19/14 02:20 PM)
#3253169 - 01/19/14 02:39 PM Re: 2001 golf reliability [Re: spasm3]
simple_gifts Offline
Loc: Middlesex County CT
Just remember it is still a 14 yo car.
2003 Echo >390K miles; Showing its age.
2006 B2300;101K;ALM
Please conserve paper; it is not like it grows on trees.
#3253187 - 01/19/14 03:05 PM Re: 2001 golf reliability [Re: spasm3]
fdcg27 Offline
Loc: OH
This has the 2.slow?
A good if gutless and pretty thirsty engine.
Between the stick and the windups, this car won't move fast.
Take your time and visit some VW boards.
This could be a good buy and 4K is probably realistic.
I'd get the dealer to do the timing belt service as part of the deal, including a new water pump.
I've replaced water pumps and tensioners on 100K Hondas that were as tight as new.
Who knows what they would have been like after another 10-20K?
Not worth the risk of having to go through all of the labor to replace a failed part that should have been replaced to begin with.
An unneccesary PITA if you DIY and an unnecessary expense if you don't.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
#3253190 - 01/19/14 03:10 PM Re: 2001 golf reliability [Re: fdcg27]
Loc: out there
Not worth the risk of having to go through all of the labor to replace a failed part that should have been repalaced to begin with.
How hard is the timing belt to replace yourself? I did notice the hwy rating is only 31mpg. That is suprising for a small car.
#3253194 - 01/19/14 03:16 PM Re: 2001 golf reliability [Re: spasm3]
fdcg27 Offline
Loc: OH
I don't know, but it may not be that hard to do.
I know that on some VAGs, like some badged as Audis, it's a real PITA, but this installation may not be too bad.
Visit some VW boards, since they'll be able to give you the skinny.
Your best bet would be to get the dealer to do it as part of the purchase price or to find a good indie and use the cost of this needed task on this 13 yo car as a bargaining chip.
Whether you do it yourself or have it done, this is a real cost for a vital service and the selling price of the car, which isn't in the same range as an equivalent Honda or Toyota to begin with, should reflect this.
#3253493 - 01/19/14 09:18 PM Re: 2001 golf reliability [Re: spasm3]
Loc: out there
I'm seeing recommendations to change timing belts at 6-7 years if you dont hit the mileage.
#3262052 - 01/27/14 09:40 PM Re: 2001 golf reliability [Re: spasm3]
dareo Offline
Loc: utah
Should be pretty reliable. Crank windows is good on those, less breakage. i wouldn't be excited about it unless it was like 4 grand or so. Don't put too much stock in the mileage. It could have sat a lot, short tripped a lot, ect. I'd rather drive my 297k tdi jetta than a 2.0 with 40k on it. The diesels have been seen hitting odometer limits (1 million km) and still going; so the chassis is proven.
They hold up very well in crashes for its age.
2016 Golf Wagon 5MT, 2014 Accord Sport 6MT, 1998 Toyota T100 5MT
Page 1 of 2 1 2 >
