Completing your 80% lower with a CNC Machine
by Merkava_4
05/25/16 07:33 PM
Motor oil Sale
by GuinnessGuy
05/25/16 07:26 PM
If Homer Simpson had a Soldering Station...
by Merkava_4
05/25/16 07:17 PM
Peerless/Tecumseh 205-024c
by ford46guy
05/25/16 07:02 PM
Clever Tire Mounting Machine from Corghi
by SubLGT
05/25/16 06:15 PM
Help - transmission filter does not fit the slot!
by 69GTX
05/25/16 06:06 PM
New Browning Buckmark
by billt460
05/25/16 05:54 PM
Signature Limits?
by 2015_PSD
05/25/16 04:48 PM
pistol grip shotgun wanted
by FirstNissan
05/25/16 04:14 PM
microGreen Memorial Day Sale
by DBMaster
05/25/16 03:18 PM
Biomed Tech internship - Osceola, FL
by Mr Nice
05/25/16 03:06 PM
New Car - First OCI Subaru Outback
by Oldswagon
05/25/16 02:43 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
107 registered (2KBMW, 901Memphis, 4WD, 04SE, 69GTX, 97prizm, 13 invisible), 1721 Guests and 325 Spiders online.
57973 Members
66 Forums
249401 Topics
Page 1 of 3 1 2 3 >
#3195103 - 11/22/13 06:31 PM Tungsten Disulfide
BigBird57 Offline
Loc: Florida
Has anyone ever used this in PCMO? I have found a site that sells this for $54 per pound. They say you mix this with oil at a rate of 1%-15% by weight.
It is ok to expect, however you have to inspect.
2002 Tahoe 5.3 PU 5w-30
2011 Toyota Sienna V6 PP-0w-20
#3195128 - 11/22/13 06:56 PM Re: Tungsten Disulfide [Re: BigBird57]
Clevy Offline
Loc: Saskatoon canada
Do they state nominal particle size.
Would you mind inboxing me with their website please.
If no website would contact info be possible.
If the particle size is micron or sub micron I'd like to try it as an oil additive.
I read that it can be added to oil using a blender. If you run the carrier oil in the blender long enough the carrier oil will heat up,then add the tungsten disqualified and blend again.
Unless using something like mmo or another solvent as a carrier that will flash off leaving only the TdS behind.
I could start brewing my own friction modifier in my garage.
Klevee's Frankenbrew.
2006 Charger RT
Miles x 2 per oil filter
#3195136 - 11/22/13 07:05 PM Re: Tungsten Disulfide [Re: BigBird57]
demarpaint Offline
Loc: NY
http://www.rosemill.com/category_s/35.htm
I use it to coat bullets, it works well in oil too, although it doesn't stay in suspension as well as MoS2. If you call them and talk to their tech people they'll fill you in on the pro's and con's.
God Bless Our Troops
#3195141 - 11/22/13 07:10 PM Re: Tungsten Disulfide [Re: BigBird57]
MolaKule Offline
Loc: Iowegia - USA
Unless it is Dialkylammonium Tungstate in oil I wouldn't use in engine oils.
"You are free to choose, but you are not free from the Consequences of your choice." Dr. Laura. smile
#3195174 - 11/22/13 07:41 PM Re: Tungsten Disulfide [Re: BigBird57]
spasm3 Online   content
Loc: out there
From what i have read, its a good friction modifier, but won't stay/maintain a suspension in oil. Lubromoly does seem to have a colloidal property and stays for the most part in suspension. Everything i've read about tungsten disulphide says it falls out immediately.
13 elantra 46k 5w30 ultra
03 chevy avalanche67k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 79k 5w30 havo
#3195208 - 11/22/13 08:18 PM Re: Tungsten Disulfide [Re: BigBird57]
BigBird57 Offline
Loc: Florida
#3195209 - 11/22/13 08:19 PM Re: Tungsten Disulfide [Re: BigBird57]
expat Offline
Loc: Canada
Castrol in the UK, in the 70's advertised their GTX had
"Liquid Tungsten"
#3195213 - 11/22/13 08:24 PM Re: Tungsten Disulfide [Re: Clevy]
BigBird57 Offline
Loc: Florida
WS2, 99.9% Pure, 0.6 micron APS @ $54 per lb.
#3195216 - 11/22/13 08:30 PM Re: Tungsten Disulfide [Re: demarpaint]
BigBird57 Offline
Loc: Florida
What vehicle did you use this product? How much additive per quart of oil?
#3195419 - 11/23/13 07:33 AM Re: Tungsten Disulfide [Re: BigBird57]
demarpaint Offline
Loc: NY
I had a pound of it which I used for coating bullets, and thought I would take a try at using it in oil. I used it in a 93 Aerostar, and an old edger which had an oil burning issue. I don't remember the dose, IIRC is was about 1 teaspoon/qt of oil. The people at Rosemill suggested the amount. It stopped the edger from using oil. The only downfall is it falls out of suspension and that's why I don't use it any longer. I later tried Lubro Moly MoS2 and found it stayed in suspension, so I stuck with it. The tech people at Rosemill were very helpful at the time with my questions. It would be worth calling them if you're interested in pursuing it further.
#3195775 - 11/23/13 02:40 PM Re: Tungsten Disulfide [Re: MolaKule]
dave5358 Offline
Loc: North Bend
Can you suggest a source or reference to this product? Except for some guy applying for a patent, I can find almost zero references to Dialkylammonium Tungstate or Dialkyl Ammonium Tungstate.
There are numerous references to Tungsten Disulfide - basically a dry film lubricant, that is gaining in application popularity.
2006 Forester XT
2008 Corolla LE
#3195784 - 11/23/13 02:59 PM Re: Tungsten Disulfide [Re: BigBird57]
MolaKule Offline
Loc: Iowegia - USA
Here is my problem with dry lubricants such as powdered moly, titanium, and Tungsten being introduced into a crankcase: Unless the dry lubricant is specially processed into a colloidal system with polarity additives, the dry lubricant may fall out of suspension and may not attach itself to friction surfaces, OR if it's a specially processed organo-metallic chemistry. Organo-metallic chemistries are only the ones that should be introduced into a formulated oil and only after extensive lab testing, engine teardown and analysis, and fleet testing.
MoDTC, special titanium compounds and dialkylammonium tungstate are specially processed organo-metallic compounds and the only ones fully soluble in motor oils.
I went to Google and easily found the following references:
http://www.rtvanderbilt.com/documents/MSDS/EU/51155.pdf
VANLUBE W-324 - Amine Tungstate AW Synergist found in:
http://www.vanderbiltchemicals.com/ee_co...omestic_Web.pdf
Edited by MolaKule (11/23/13 03:04 PM)
#3195885 - 11/23/13 05:18 PM Re: Tungsten Disulfide [Re: MolaKule]
dave5358 Offline
Loc: North Bend
Okay, but you should have easily found that there was not much information at the Vanderbilt link above, except that VANLUBE W-324, their product containing dialkylammonium tungstate, is listed as a 'new product'.
If you search for VANLUBE W-324, here's the spec sheet. But, there's not much real information here either, particularly as to applications. Four product tests are listed, for one of which one of Vanderbilt's own moly product actually performed slightly better. For all of the tests, it's worth noting that the performance differences between the various products tested was very slight - truly microscopic - if you study the scales on the charts. But, VANLUBE W-324 is an interesting product nonetheless.
MoS2 falling out of suspension is a known issue. Sub-micron particle size seems to be a suitable fix. I've not read of issues involving MoS2 not attaching to metal surfaces.
... OR if it's a specially processed organo-metallic chemistry. Organo-metallic chemistries are only the ones that should be introduced into a formulated oil and only after extensive lab testing, engine teardown and analysis, and fleet testing.
Where do you get this stuff? It really sounds good, but according to this Wiki's article on organo-metallic chemistry, there's no particular link between this very new technology and oil additives. In any event, the bond between MoS2 and metal surfaces should be mechanical - not chemical. MoS2 is not soluble in oil (or much of anything else). But, I'm clearly not a chemist.
As for "extensive lab testing, engine teardown and analysis and fleet testing" we all want that. Who wouldn't want that kind of information? But if that's the standard to be met before using an additive, there would be no additives.
There's a small body of this information on Molybdenum Disulfide used as an oil additive (but clearly not enough to satisfy detractors). And this is a product which has been in rather widespread industrial use for about a century. We can only hope this type of testing is someday done on the organo-metallic flavors of molybdenum and titanium.
2006 Forester XT
2008 Corolla LE
#3195906 - 11/23/13 05:45 PM Re: Tungsten Disulfide [Re: MolaKule]
dave5358 Offline
Loc: North Bend
Upon further reflection, I think I was much too kind. You specifically do not want a soluble form of tungsten or molybdenum in the oil (which seems to be the claimed goal of organo-metallic chemistry, at least your reference). As before, small particle size is a suitable fix for settling issues.
If the additive is soluble, it will drain out when the engine stops - just like the oil in the Lucas gear-crank toy mentioned earlier in this thread. In may drain faster or slower - basically the take-away from the Lucas toy. But, once it drains out - no more lubrication. One of the nice features of MoS2 is that it does not drain out. It more-or-less stays put on the bearing surfaces. You get dry-film lubrication at start up, and you can keep driving if you take a bullet in your engine pan. In that narrow sense, MoS2 doesn't make for a 'better oil'. Rather, it's more of an oil substitute, which does not interfere with the motor oil's normal functioning.
But MoS2 (and probably Tungsten Disulfide) is a very slippery substance, it reduces friction, heat and it is highly resistant to extreme pressure. Viewed in that way, it might make a 'better oil'.
2006 Forester XT
2008 Corolla LE
#3196104 - 11/23/13 09:37 PM Re: Tungsten Disulfide [Re: MolaKule]
BigBird57 Offline
Loc: Florida
This is why I like the forum. It sounds like the tungsten disulfide is not quite ready for prime time in PCMO. I can see a use on a bolt action rifle in extremely cold weather. I run Pennzoil Ultra so I will resist the temptation to experiment with this dry lubricant.
Page 1 of 3 1 2 3 >
