Wiper insert spring steel
by SHOZ
05/04/16 01:52 PM
BMW X1 / N20 2.0L Turbo - what oil ?
by Ndx
05/04/16 12:02 PM
1999 RANGER 3.0 SYNTHETIC OIL SUGGESTIONS
by AUTOTECH89
05/04/16 10:56 AM
Oil spec questions
by IllinoisSparky
05/04/16 10:43 AM
Amazing Rendition of the U.S. National Anthem
by MolaKule
05/04/16 10:37 AM
So many detailing products........
by buster
05/04/16 10:00 AM
Why is Mobil Delvac 1 so expensive?
by pb379
05/04/16 10:00 AM
2017 F-150 3.5 twin turbo V6
by OneEyeJack
05/04/16 09:45 AM
Fort McMurray Fire 80,000 evacuated
by Smokescreen
05/04/16 09:40 AM
Apparent dilution ratio discrepancy????
by Sayjac
05/04/16 09:31 AM
Ceramic brake pads
by bigdom
05/04/16 09:24 AM
how to verify oil in a manual transmission
by yvon_la
05/04/16 09:21 AM
NatedeScate, Bogie69, Cali, Fyko, Palmer
57794 Registered Users
80 registered (2015_PSD, 69GTX, 2009Edge, Andrei, AntsinmyEyes, 2010Civic, 14 invisible), 0 Guests and 1 Spider online.
57794 Members
66 Forums
248457 Topics
Page 2 of 2 < 1 2
#3165849 - 10/24/13 07:12 AM Re: Put RESTORE in the old Chevy [Re: Richtrashman]
Miller88 Offline
Loc: Onondaga County
Originally Posted By: Richtrashman
Originally Posted By: Miller88
If you have a 5 cyl mix the 4 and 6 cylinder formula!
that would be for a V10!
If little is good, more is better. :P
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
#3166184 - 10/24/13 12:10 PM Re: Put RESTORE in the old Chevy [Re: Richtrashman]
Phishin Offline
Loc: Indiana
PHISHIN---so I read all 9 of your pages and looked at the pics, what do you think your final answer would be regarding the use of restore? as far as using it ($) every oil change it doesn't bother me much, if I cut down on oil consumption the cost balances out.do you think I should change the filter after 500 or so? also do you think that the combination and the volume of several additives could have caused all the goo in your filters? maybe the particulates were from normal engine breakdown (yours obviously had some!)that was stuck in the sludge of the engine you said was there? not doubting your findings by any means just trying a different p.o.v. thanks in advance
main question would you use it again?
Yes, I would use again. In fact, RESTORE is in the oil right now.
I thinking changing the oil filter after 500 miles isn't a bad idea. Is it needed? I don't think so. Heck, why don't you add RESTORE, and run it from 500 or go 3000 miles, and replace the filter? Cut your old one open and show us the results. Just don't cut the filter open with a Dremel like I did. It can contaminate your results.
This spring, I'll send my oil filter to someone on here with a filter cutter and post pics with another run of RESTORE.
Yes, I'd run RESTORE again. Yes, it's in my truck now. For me, since I burn a quart of oil every 500-1000 miles, and since I won't go over 3k miles with any filter, I don't change the oil. I just keep adding.
When I started my "RESTORE experiment", I added two cans of the 6-cylinder cans. Since then, I've topped my truck off with 9-10 quarts of oil, and I added another 6-cylinder can. I've changed out the filter twice.
Edited by Phishin (10/24/13 12:11 PM)
2010 Accord-LX K24: PU 5w30
2009 Subaru Forester 2.5X: M1 TDT
1990 Chevy K1500 350TBI: Frankenbrew
2008 Ruckus 50ccGET: M1R Mix
#3166236 - 10/24/13 01:12 PM Re: Put RESTORE in the old Chevy [Re: Phishin]
Richtrashman Offline
Loc: Cincinnati OH
Phishin--- thanks for the reply! Will keep an eye on the pressure gauge and will post pics of the filter when I change and cut it. May take a bit, only put maybe 800 miles a month on it, anxious to see results or not! Will keep ya all posted
2010 Optima 88k+ valv ML, ML ATF
1990 c2500 173k+ any
2005 Xterra 91k ML ATF
In the land of the blind the one eyed man is King
#3179104 - 11/05/13 11:16 AM Re: Put RESTORE in the old Chevy [Re: Richtrashman]
strat81 Offline
Loc: Nebraska
A member on GMTNation used it in her Trailblazer with the 4.2L inline 6. The engine did not like it, threw all kinds of codes, etc.
Molon Labe
#3179121 - 11/05/13 11:36 AM Re: Put RESTORE in the old Chevy [Re: strat81]
racin4ds Offline
Loc: Winchester, VA
Ummm no. there isn't a sensor on a vehicle that could pick up the fact that this stuff is in the oil and throw a CEL. Its [censored] like this that spreads internet rumors!
Just say NO to thin oils!
#3179496 - 11/05/13 05:14 PM Re: Put RESTORE in the old Chevy [Re: racin4ds]
michaelluscher Offline
Loc: Tri States Little Italy
While I agree in this circumstance, What about an engine WITH! Some sort of sensor that could be put off by something in the oil? VVT/VTEC/MDS/AFM/VCM/MIVEC-MD..... etc
'06 Toyota Camry SE V6 3MZ-FE 51k
'01 Mercury Villager Estate VG33E 48k
'06 Ford Taurus SE Vulcan 48k
'13 Chrysler 300 3.6 Pentastar 45k
2012-2015
#3180713 - 11/06/13 08:34 PM Re: Put RESTORE in the old Chevy [Re: michaelluscher]
Phishin Offline
Loc: Indiana
I don't think I'd use Restore in any high-tech engine with a potentially corruptible sensor unless I didn't care if something did go haywire.
I've read some things online (I think Amazon reviews) where people claimed cam shaft sensors and possibly VVT was affected immediately after adding Restore. I can see that happening. I mean, you're pouring in heavy dose of soft, conductive metals into your oil....things could happen.
I think Restore is best used for old-school, low tech engines. If your engine has a distributor cap, you're probably fine. If your engine utilizes variable valve timing or even has a cam sensor, you might want to think twice about pouring Restore into your crankcase.
#3180736 - 11/06/13 08:57 PM Re: Put RESTORE in the old Chevy [Re: Phishin]
demarpaint Offline
Loc: NY
Well said.
God Bless Our Troops
#3180834 - 11/06/13 10:36 PM Re: Put RESTORE in the old Chevy [Re: demarpaint]
Well said.
I agree...
Clapped out 305 or 351, It's a last ditch effort hide
3MZ-FE or VQ... Just.... Just no crush
2012-2015
#3194478 - 11/22/13 05:57 AM Re: Put RESTORE in the old Chevy [Re: Richtrashman]
Loc: Cincinnati OH
Well, it has been almost a month exactly, about 770 miles since I added the RESTORE. I have to admit it did nothing to reduce the oil consumption. I didn't really expect much on that end due to valve seals, not necessarily scratched up cylinder walls.I would like to think I feel a little more power but it could be placebo effect. I did take the advice to change the filter at around 400 miles, because I was hearing some chatter like it was starving for lube, and the oil pressure had dropped maybe 5 psi. Put on new filter, problem solved, which leads me to a new question. These SBC engines are supposed to have a built in bypass in the block correct? Can (does) this malfunction?
#3215397 - 12/13/13 10:32 AM Re: Put RESTORE in the old Chevy [Re: Richtrashman]
Bgallagher Offline
Loc: Boston, MA
lol
2005 Chevy Equinox - 137k -Penn. HM/AC PF52 (non e-core)
2005 Chevy Malibu - 167k - Penn. HM/AC PF457G
2015 GMC Terrain - 5.3k- Delco Dexos 1 and PF457G
#3216683 - 12/14/13 05:36 PM Re: Put RESTORE in the old Chevy [Re: Richtrashman]
Errtt Offline
Loc: California
Yes use all for a 10, but you can use half for a 5
#3223098 - 12/20/13 07:59 PM Re: Put RESTORE in the old Chevy [Re: Richtrashman]
CourierDriver Offline
Loc: USA
The engine is 23years old,,either rebuild it or put in a crate engine for about 3300 bucks and ride on,,,imho Its mechanical, they dont last forever.
Look at your check book and see where your priorities are...
Page 2 of 2 < 1 2
