I have used larger then OEM size filters on several cars with no ill effects, however, I have revised my opinion on filters in general. I honestly do not believe they perform a useful function other then catastrophic protection as it is the oil that does all the work. The wear metals that show up in analysis are too small to be captured and most likely have no effect on further engine wear. So if you change your oil under 5000 miles I believe one can use any filter, 5000-10,000 maybe make a difference but I haven't seen any studies to prove longevity with quality filters versus less expensive versus 3000 mile versus 10,000 mile intervals. Just my opinion.
