Chryler's of your era use G-05, they simply dye it orange.
Ford's OEM coolant for the same era is G-05. Zerex has a G-05.
It's all the same stuff, nothing outside of G-05.
I would NOT use anything but G-05 because using a different antifreeze may or may not be compatible with the different metals in the engine, even though you are using it as a flush, you won't be able to get all of the "green" out.
What I'd do is get several gallons of distilled water.
drain out the chrysler antifreeze and fill up with distilled water, let it run & drain out via the draincock on the radiator (it should have one?!). If you're gonna run a flushing addtive, go for it too.
when you're satisfied and all the soap is out from the flush, drain out the distilled and pour in more distilled, let it all run through & out.
let that water drain out, then with the empty gallon containers, make your magical 50/50 potion of G-05 and distilled water.
However, what I personally do is dope up the g-05 a bit more because I know there's still water in the block I can't get out.
so I do like a 60/40 mixture just to offset.
Now you just fill up and you don't have to worry about having to much/little of water/antifreeze.
